[Geomoose-users] Multiple Mapbook.xml
James Klassen klassen.js at gmail.com
Thu Nov 17 06:13:50 PST 2016
There are two options buult into GeoMoose:
A partial option (works for the html/js part of GeoMoose only, not the PHP
services) is to add a
?mapbook=url-to-mapbook.xml
to the GeoMoose URL.
The other option is to modify getmapbook.php (maybe the actual function is
in config.php, it isn't in front of me) to be aware of the user that is
logged in and return the appropriate mapbook.  One of the reasons
getmapbook.php exists is to create a spot where people could hook in this
type of functionality.
IIRC a couple of the PHP services that need mapbook data also use this
method so they should keep working.
On Nov 16, 2016 13:59, "Kevin Grootendorst" <kgrootendorst at gmail.com> wrote:
> Hello users, I'm looking to create multiple GeoMoose sites within the same
> GeoMoose installation.
> I see that Mapbook.xml is referenced by 'settings.ini' which in turn is
> referenced by 'config.php'.
> I would like to be able to have User A hit Mapbook_A.xml, User B hit
> Mapbook_B.xml, etc.
> Can anyone shed light on how to accomplish this.  I didn't notice anything
> in the documentation(?).
> Using GeoMoose 2.8.1.
> Thanks, Kevin
> Geomoose-users mailing list
> Geomoose-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20161117/03a0ca53/attachment.html>
More information about the Geomoose-users mailing list
