[Geomoose-users] Identify tool on a raster WMS layer
andy aborruso at gmail.com
Wed Feb 1 14:24:18 PST 2017
Hi James,
On 1 February 2017 at 23:12, James Klassen <klassen.js at gmail.com> wrote:
http://docs.geomoose.org/2.9/howto/popups.html?highlight=
> popup#enable-wms-queries-in-the-mapfile
> Raster should be same vector except for what substitution variables are
> available.
I have added a CLASS with a NAME, but it does not work.
And it does not work also if I add the same layer as map-source
type="mapserver".
If I use it as map-source type="mapserver" I have
The service you called did not return valid XML. If you are the system
administrator, you should look into this, if you are not the system
administrator you should tell them about this.
Instead if I use it as map-source type="wms" I have only the coordinates
click.
What do you think about?
Thank you very much
Andrea Borruso
website: http://blog.spaziogis.it
38° 7’ 48” N, 13° 21’ 9” E, EPSG:4326
“cercare e saper riconoscere chi e cosa,
in mezzo all’inferno, non è inferno,
e farlo durare, e dargli spazio”
Italo Calvino
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20170201/87931d0f/attachment.html>
More information about the Geomoose-users mailing list
