[Geomoose-users] Query a Mapserver raster group
Jim Klassen klassen.js at gmail.com
Wed Feb 1 15:34:06 PST 2017
My guess:
Put both layers in the the same group (also note that MAP->NAME is also
an implicit top level group).  IIRC both layers have to be queryable (in
they need a TEMPLATE keyword defined, but the template itself may be
empty, or not even exist.  I often use TEMPLATE 'dummy').
You will need some trick to make the DEM layer not draw.  I'm not sure
the best way to approach this.  Some ideas: doing something with CLASSes
or setting OPACITY to 0.  There used to be a MAP->LAYER->TYPE QUERY that
was for this purpose, but I don't know if it still exists or if it would
work with raster data.
On 02/01/2017 05:12 PM, andy wrote:
> Hi,
> I have a map file with a group and I’m able to load this in my map.
> In this group I have:
> a DEM, in wich in each pixel I have the height valure;
> an hillshade of the this DEM to have something better in terms of
> appearance.
> I would like to load the group, see the hillshade, and when click on
> it via Geomoose identify tool to have the height values of the DEM.
> If I load only the DEM and use Geomoose identify tool I obtain the
> height values. Than I have created this mapserver group and inserted
> in the DEM layer the |wms_group_title| parameter.
> But when I load the group, the Geomoose identify tool gives me only
> the coordinates.
> Is there some alternative to obtain my goal? To view a layer, but to
> query another one?
> Thank you
> Andrea Borruso
> website: http://blog.spaziogis.it
> 38° 7’ 48” N, 13° 21’ 9” E, EPSG:4326
> “cercare e saper riconoscere chi e cosa,
> in mezzo all’inferno, non è inferno,
> e farlo durare, e dargli spazio”
> Italo Calvino
> Geomoose-users mailing list
> Geomoose-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geomoose-users
More information about the Geomoose-users mailing list
