[Geomoose-users] Identify with a https WMS source
James Klassen klassen.js at gmail.com
Mon Feb 6 08:06:31 PST 2017
Not a PHP expert here so I am not sure how to go about f:bding the root
error message, but with every other language I have used, only working with
the checks disabled means there was a certificate error so either the https
server's certificate is bad (easy to chec, a web browser would also show a
warning when visiting the site) or that the client program can't find the
it's list of trusted certificate authorities (and so will think all
certificates are invalid).
The best fix would be to figure out why the certificate isn't validating
and fix that.
If you need to talk to a server with a bad certificate, can't fix the
server, and don't care if the connection is secure, then turning off the
checks is a work around.
On Feb 6, 2017 9:41 AM, "Brent Fraser" <bfraser at geoanalytic.com> wrote:
Otherwise no text is available in $gml after:
        $gml = curl_exec($curlHandle);
but maybe there is a better solution?
Best Regards,
Brent Fraser
On 2/6/2017 7:29 AM, James Klassen wrote:
Why do you need those options? Generally,! disabling the certificate checks
isn't a good idea.
On Feb 5, 2017 8:45 PM, "Brent Fraser" <bfraser at geoanalytic.com> wrote:
Hi all,
  To get identify.php to work when I specify a WMS map-source using https
(instead of the old and out-dated http), I had to add a couple of curl
options to identify.php around line 196:
        curl_setopt($curlHandle, CURLOPT_SSL_VERIFYHOST, 0);
        curl_setopt($curlHandle, CURLOPT_SSL_VERIFYPEER, 0);
Should I file an issue or is this already handled in 3.0?
And what's with hardcoding "INFO_FORMAT=application/vnd.ogc.gml" into the
request?  Should we make that configurable in the map-source definition?
Thanks!
Best Regards,
Brent Fraser
Geomoose-users mailing list
Geomoose-users at lists.osgeo.org
https://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20170206/25dc494f/attachment.html>
More information about the Geomoose-users mailing list
