[Geomoose-users] Identify with a https WMS source
Mark Volz MarkVolz at co.lyon.mn.us
Mon Feb 6 10:01:12 PST 2017
Just to add my two cents in here.  Some organizations might want to have https enabled, but do not have a need that justifies purchasing a ssl certificate…
Thanks
Sincerely,
Mark Volz, GISP
From: Geomoose-users [mailto:geomoose-users-bounces at lists.osgeo.org] On Behalf Of Brent Fraser
Sent: Monday, February 06, 2017 10:14 AM
To: James Klassen <klassen.js at gmail.com>
Cc: GeoMOOSE Users List <geomoose-users at lists.osgeo.org>
Subject: Re: [Geomoose-users] Identify with a https WMS source
Hey Jim,
  I think our WMS server's certificate is ok (no errors shown) but I'll confirm that.  It could be my PHP config so I will look into that too.
  Thanks!
Best Regards,
Brent Fraser
On 2/6/2017 9:06 AM, James Klassen wrote:
Not a PHP expert here so I am not sure how to go about f:bding the root error message, but with every other language I have used, only working with the checks disabled means there was a certificate error so either the https server's certificate is bad (easy to chec, a web browser would also show a warning when visiting the site) or that the client program can't find the it's list of trusted certificate authorities (and so will think all certificates are invalid).
The best fix would be to figure out why the certificate isn't validating and fix that.
If you need to talk to a server with a bad certificate, can't fix the server, and don't care if the connection is secure, then turning off the checks is a work around.
On Feb 6, 2017 9:41 AM, "Brent Fraser" <bfraser at geoanalytic.com<mailto:bfraser at geoanalytic.com>> wrote:
Otherwise no text is available in $gml after:
        $gml = curl_exec($curlHandle);
but maybe there is a better solution?
Best Regards,
Brent Fraser
On 2/6/2017 7:29 AM, James Klassen wrote:
Why do you need those options? Generally,! disabling the certificate checks isn't a good idea.
On Feb 5, 2017 8:45 PM, "Brent Fraser" <bfraser at geoanalytic.com<mailto:bfraser at geoanalytic.com>> wrote:
Hi all,
  To get identify.php to work when I specify a WMS map-source using https (instead of the old and out-dated http), I had to add a couple of curl options to identify.php around line 196:
        curl_setopt($curlHandle, CURLOPT_SSL_VERIFYHOST, 0);
        curl_setopt($curlHandle, CURLOPT_SSL_VERIFYPEER, 0);
Should I file an issue or is this already handled in 3.0?
And what's with hardcoding "INFO_FORMAT=application/vnd.ogc.gml" into the request?  Should we make that configurable in the map-source definition?
Thanks!
Best Regards,
Brent Fraser
Geomoose-users mailing list
Geomoose-users at lists.osgeo.org<mailto:Geomoose-users at lists.osgeo.org>
https://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20170206/7bcba1e6/attachment.html>
More information about the Geomoose-users mailing list
