[Geomoose-users] Identify with a https WMS source
Brent Fraser bfraser at geoanalytic.com
Mon Feb 6 12:33:19 PST 2017
Eli,
   And the mapcache doc claims that when using it to generate TMS tiles
from mapserver it will pass GetFeatureInfo requests (Geomoose
"Identify") along to mapserver.  So I'm hacking identify.php to wotk on
TMS map-sources to test that....
Best Regards,
Brent Fraser
On 2/6/2017 11:53 AM, Eli Adam wrote:
> slightly off-topic: This is more of a MapServer question but relates
> to GeoMoose as a client too.  Can MapServer serve WMS/WFS over https?
> I've not found it in the docs or email lists (but my searching may be
> at fault).
> Best regards, Eli
> On Mon, Feb 6, 2017 at 10:39 AM, Jeff McKenna
> <jmckenna at gatewaygeomatics.com> wrote:
>> Hi Brent,
>> MS4W includes an important file for this, the CA certificate bundle, and
>> Apache's httpd.conf points to it (see
>> http://ms4w.com/README_INSTALL.html#k-certificates-for-https-with-wms-wfs-servers).
>> However sometimes MS4W gets upgraded and that little file is forgotten in
>> the release package (I believe this was missing in MS4W 3.1.4); the file is
>> included in the recent MS4W 3.2.0 release.  But if you ever notice anything
>> missing in an MS4W, please file a ticket right away on that at
>> http://ms4w.com/trac (otherwise that little file will be missed in the next
>> release).
>> -jeff
>> On 2017-02-05 10:45 PM, Brent Fraser wrote:
>>> Hi all,
>>>    To get identify.php to work when I specify a WMS map-source using
>>> https (instead of the old and out-dated http), I had to add a couple of
>>> curl options to identify.php around line 196:
>>>          curl_setopt($curlHandle, CURLOPT_SSL_VERIFYHOST, 0);
>>>          curl_setopt($curlHandle, CURLOPT_SSL_VERIFYPEER, 0);
>>> Should I file an issue or is this already handled in 3.0?
>>> And what's with hardcoding "INFO_FORMAT=application/vnd.ogc.gml" into
>>> the request?  Should we make that configurable in the map-source
>>> definition?
>>> Thanks!
>> Jeff McKenna
>> MapServer Consulting and Training Services
>> http://www.gatewaygeomatics.com/
>> Geomoose-users mailing list
>> Geomoose-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/geomoose-users
More information about the Geomoose-users mailing list
