[Geomoose-users] v2.9 identify tab will not close
Dan Little
theduckylittle at gmail.com
Fri Jan 6 11:40:56 PST 2017
Thanks for posting the solution Kevin!
On Fri, Jan 6, 2017 at 11:02 AM, Kevin Grootendorst
<kgrootendorst at gmail.com> wrote:
> Tim and others,
> I solved my problem.
> It had to do with my mapbook.xml file.
> Using the demo as reference, I added in the following map sources to my
> mapbook.xml:
> <map-source name="vector_highlight" type="geojson" status="off">
> <style type="stylemap"><![CDATA[
> "strokeColor" : "#ffff00",
> "strokeOpacity" : 1.0,
> "fillColor" : "#ffff00",
> "fillOpacity" : 0.25
> ]]></style>
> <url></url>
> </map-source>
> <map-source name="highlight" type="mapserver">
> <file/>
> <layer name="highlight" status="off"/>
> <param name="TRANSPARENT" value="TRUE"/>
> </map-source>
> This has fixed the problem. My identify tool will now close properly.
> In hindsight, I now understand that the firebug error was telling me that I
> had a problem with one of my map sources so that it where I should have
> looked in the first place. I hope this thread will help others.
> Cheers,
> Kevin
> On Fri, Jan 6, 2017 at 11:10 AM, Tim Hennig <timhbellevue at gmail.com> wrote:
>> Hi Kevin,
>> I am not sure if this relates to your issue, but I am working on testing
>> the 2.9 version and hopefully implement it later this month, etc.
>> I transferred the code configuration changes and add-ons from 2.8.1 to
>> 2.9.0 and started getting the same issue pertaining to identifying (and
>> other tools) not closing. Ran the Firebug to figure what was going on and
>> had no luck. So, I started to transfering the code one-by-one and
>> discovered (don't know how I discovered it) that the <meta
>> http-equiv="X-UA-Compatible" content="IE=EmulateIE9"> was causing the issue
>> in the geomoose.html. I added this awhile back because of IE compatibility
>> issue from previous versions of GeoMoose. Once I removed it everything
>> started working...
>> Hope this helps,
>> Tim Hennig, GIS/IT Manager
>> Village of Bellevue | 2828 Allouez Avenue | Bellevue, Wisconsin 54311
>> -----Original Message-----
>> From: Geomoose-users [mailto:geomoose-users-bounces at lists.osgeo.org] On
>> Behalf Of geomoose-users-request at lists.osgeo.org
>> Sent: Thursday, January 05, 2017 2:00 PM
>> To: geomoose-users at lists.osgeo.org
>> Subject: Geomoose-users Digest, Vol 65, Issue 3
>> Send Geomoose-users mailing list submissions to
>> To subscribe or unsubscribe via the World Wide Web, visit
>> http://lists.osgeo.org/mailman/listinfo/geomoose-users
>> or, via email, send a message with subject or body 'help' to
>> You can reach the person managing the list at
>> geomoose-users-owner at lists.osgeo.org
>> When replying, please edit your Subject line so it is more specific than
>> "Re: Contents of Geomoose-users digest..."
>> Today's Topics:
>> 1. v2.9 identify tab will not close (Kevin Grootendorst)
>> Message: 1
>> Date: Thu, 5 Jan 2017 12:07:34 -0500
>> From: Kevin Grootendorst <kgrootendorst at gmail.com>
>> To: GeoMOOSE Users List <geomoose-users at lists.osgeo.org>
>> Subject: [Geomoose-users] v2.9 identify tab will not close
>> Message-ID:
>> <CAOS-Y4nMQWhk_AbE7tOijtYXjGPSTk1Vc1h=fYX-_3QXewvEog at mail.gmail.com>
>> Content-Type: text/plain; charset="utf-8"
>> Dear list,
>> I recently upgraded to v2.9.0 from 2.8.1. I have noticed that the
>> identify tool works to display attributes, but will not close when I click
>> the 'close' button or the 'x' at the top of the identify tab.
>> Firebug gives me this error: TypeError: Application.getMapSource(...) is
>> undefined, and references geomoose.js (line 286, col 3). This section of
>> the .js code appears unchanged from v2.8.1, so I don't know why it's
>> throwing this error.
>> Has anyone else experienced this?
>> Thanks,
>> Kevin
>> -------------- next part --------------
>> An HTML attachment was scrubbed...
>> URL:
>> <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20170105/e8e563fa/attachment-0001.html>
>> Subject: Digest Footer
>> Geomoose-users at lists.osgeo.org
>> End of Geomoose-users Digest, Vol 65, Issue 3
More information about the Geomoose-users
