[Geomoose-users] Metadata link
Basques, Bob (CI-StPaul)
bob.basques at ci.stpaul.mn.us
Wed Jan 11 07:06:04 PST 2017
Kevin,
I believe that icon is part of the GeoMOOSE icon sprite image. (one image for all the icons)
You should be able to see the raw image (with all the icons) in it by right-clicking on the binocular icon and viewing the background image. I did this with firefox to display the image that the icons are sourced from. You can either replace the icon sprite image with one of your own or I believe you can substitute individual icon images in the mapbook, but I’ve not done this in quite a while myself, so someone else will need to chime in on how that’s done in the latest versions. I do know that the more images you introduce, the slower the interface will be when loading.
bobb
On Jan 10, 2017, at 6:12 PM, Kevin Grootendorst <kgrootendorst at gmail.com<mailto:kgrootendorst at gmail.com>> wrote:
Dear list,
I would like to add a metadata link beside certain layers in my catalog. I see from the demo that a link can easily be added. I would like to customize the location of the link icon, and also the icon itself.
In the attached graphic, I've enabled metadata for the layer 'DEM Tile Index'. However, the icon used for it is a set of binoculars and the link is located beneath the layer. I would like to re-position the link to be beside the layer name and use a different icon.
Can someone point me to the file that contains this item so that I can customize? I can't seem to locate it.
I found this site which incorporates these changes:
http://geomoose.lyonco.org/geomoose/lyonMaindemo.html
Thanks.
Kevin
<Metadata_link.PNG>_______________________________________________
Geomoose-users mailing list
Geomoose-users at lists.osgeo.org<mailto:Geomoose-users at lists.osgeo.org>
http://lists.osgeo.org/mailman/listinfo/geomoose-users
"I've had a wonderful time, but this wasn't it."
- Groucho Marx
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20170111/bd42734d/attachment.html>
More information about the Geomoose-users
