[Geomoose-users] Metadata link
Kevin Grootendorst kgrootendorst at gmail.com
Wed Jan 11 09:48:40 PST 2017
Thanks Bob and Dan for the responses.
Dan - I'm okay with having all layer tools next to the layer title. In
fact, I will only have the metadata link tool anyway in this application.
Can you elaborate on the code change(s) needed to implement this change?
Thanks.
Kevin
On Wed, Jan 11, 2017 at 12:26 PM, Dan Little <theduckylittle at gmail.com>
wrote:
> You can also override the CSS for that particular tool to change the
> look.  Changing the position is a bit more difficult because we have a
> lot of the DOM work done in Javascript in ways that aren't easily
> subclassed or overridden.
> Moving the metadata tool next to the layer title will move ALL of the
> On Wed, Jan 11, 2017 at 9:06 AM, Basques, Bob (CI-StPaul)
> <bob.basques at ci.stpaul.mn.us> wrote:
> > Kevin,
> > I believe that icon is part of the GeoMOOSE icon sprite image. (one image
> > for all the icons)
> > You should be able to see the raw image (with all the icons) in it by
> > right-clicking on the binocular icon and viewing the background image.  I
> > did this with firefox to display the image that the icons are sourced
> from.
> > You can either replace the icon sprite image with one of your own or I
> > believe you can substitute individual icon images in the mapbook, but
> I’ve
> > not done this in quite a while myself, so someone else will need to
> chime in
> > on how that’s done in the latest versions.  I do know that the more
> images
> > you introduce, the slower the interface will be when loading.
> > bobb
> > On Jan 10, 2017, at 6:12 PM, Kevin Grootendorst <kgrootendorst at gmail.com
> > wrote:
> > Dear list,
> > I would like to add a metadata link beside certain layers in my
> catalog.  I
> > see from the demo that a link can easily be added.  I would like to
> > customize the location of the link icon, and also the icon itself.
> > In the attached graphic, I've enabled metadata for the layer 'DEM Tile
> > Index'.  However, the icon used for it is a set of binoculars and the
> link
> > is located beneath the layer.  I would like to re-position the link to be
> > beside the layer name and use a different icon.
> > Can someone point me to the file that contains this item so that I can
> > customize?  I can't seem to locate it.
> > I found this site which incorporates these changes:
> > http://geomoose.lyonco.org/geomoose/lyonMaindemo.html
> > Thanks.
> > Kevin
> > <Metadata_link.PNG>_______________________________________________
> > Geomoose-users mailing list
> > Geomoose-users at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/geomoose-users
> > "I've had a wonderful time, but this wasn't it." - Groucho Marx
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20170111/6272ce89/attachment.html>
More information about the Geomoose-users mailing list
