[Geomoose-users] Metadata link
Kevin Grootendorst kgrootendorst at gmail.com
Wed Jan 25 06:11:20 PST 2017
Dan - I noticed this ticket is now closed. Does this mean that it will be a
part of the 2.9.3 release? I'm not familiar with GitHub.
Our client is requesting the metadata link beside the layer name, with an
option to have a meaningful icon for the link.
Thanks,
Kevin
On Wed, Jan 11, 2017 at 4:33 PM, Dan Little <theduckylittle at gmail.com>
wrote:
> I just went through that code and it looks like we may have deprecated
> the configuration option of putting the layer controls next to the
> layer title.
> And when I looked to do a CSS hack I realized that we don't have good
> class names there either!
> I created this ticket to address that problem:
> - https://github.com/geomoose/geomoose/issues/162
> I'm going to try and get it done today but it may not make it into
> 2.9.1 as I don't know if Jim started work on the release yet.
> On Wed, Jan 11, 2017 at 11:48 AM, Kevin Grootendorst
> <kgrootendorst at gmail.com> wrote:
> > Thanks Bob and Dan for the responses.
> > Dan - I'm okay with having all layer tools next to the layer title. In
> fact,
> > I will only have the metadata link tool anyway in this application.
> > Can you elaborate on the code change(s) needed to implement this change?
> > Thanks.
> > Kevin
> > On Wed, Jan 11, 2017 at 12:26 PM, Dan Little <theduckylittle at gmail.com>
> > wrote:
> >> You can also override the CSS for that particular tool to change the
> >> look.  Changing the position is a bit more difficult because we have a
> >> lot of the DOM work done in Javascript in ways that aren't easily
> >> subclassed or overridden.
> >> Moving the metadata tool next to the layer title will move ALL of the
> >> On Wed, Jan 11, 2017 at 9:06 AM, Basques, Bob (CI-StPaul)
> >> <bob.basques at ci.stpaul.mn.us> wrote:
> >> > Kevin,
> >> > I believe that icon is part of the GeoMOOSE icon sprite image. (one
> >> > image
> >> > for all the icons)
> >> > You should be able to see the raw image (with all the icons) in it by
> >> > right-clicking on the binocular icon and viewing the background image.
> >> > I
> >> > did this with firefox to display the image that the icons are sourced
> >> > from.
> >> > You can either replace the icon sprite image with one of your own or I
> >> > believe you can substitute individual icon images in the mapbook, but
> >> > I’ve
> >> > not done this in quite a while myself, so someone else will need to
> >> > chime in
> >> > on how that’s done in the latest versions.  I do know that the more
> >> > images
> >> > you introduce, the slower the interface will be when loading.
> >> > bobb
> >> > On Jan 10, 2017, at 6:12 PM, Kevin Grootendorst
> >> > wrote:
> >> > Dear list,
> >> > I would like to add a metadata link beside certain layers in my
> catalog.
> >> > I
> >> > see from the demo that a link can easily be added.  I would like to
> >> > customize the location of the link icon, and also the icon itself.
> >> > In the attached graphic, I've enabled metadata for the layer 'DEM Tile
> >> > Index'.  However, the icon used for it is a set of binoculars and the
> >> > link
> >> > is located beneath the layer.  I would like to re-position the link to
> >> > be
> >> > beside the layer name and use a different icon.
> >> > Can someone point me to the file that contains this item so that I can
> >> > customize?  I can't seem to locate it.
> >> > I found this site which incorporates these changes:
> >> > http://geomoose.lyonco.org/geomoose/lyonMaindemo.html
> >> > Thanks.
> >> > Kevin
> >> > <Metadata_link.PNG>_______________________________________________
> >> > Geomoose-users mailing list
> >> > Geomoose-users at lists.osgeo.org
> >> > http://lists.osgeo.org/mailman/listinfo/geomoose-users
> >> > "I've had a wonderful time, but this wasn't it." - Groucho Marx
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20170125/71ce8a2a/attachment.html>
More information about the Geomoose-users mailing list
