[Geomoose-users] Metadata link
Dan Little theduckylittle at gmail.com
Wed Jan 25 07:27:21 PST 2017
I just tested "2.9", which if it is on 2.9.2 then we got the change into
2.9.2 as well.
On Jan 25, 2017 09:14, "Jim Klassen" <klassen.js at gmail.com> wrote:
2.9.3 or 2.9.2?  http://demo.geomoose.org/2.9/ should be at 2.9.2 right
now.  http://demo.geomoose.org/master/ will likely become 2.9.3 when ready.
On 01/25/2017 08:37 AM, Dan Little wrote:
The CSS changes should be included in the 2.9.3 package.
I just verified on http://demo.geomoose.org/2.9/
You'll need to add the following to your site.css file...
.spite-control.sprite-control-metadata {
 /* style the metadata icon */
.catalog-layer-controls {
 display: inline-block;
.catalog-layer-titlebar {
On Wed, Jan 25, 2017 at 8:11 AM, Kevin Grootendorst <kgrootendorst at gmail.com
> wrote:
> Dan - I noticed this ticket is now closed. Does this mean that it will be
> a part of the 2.9.3 release? I'm not familiar with GitHub.
> Our client is requesting the metadata link beside the layer name, with an
> option to have a meaningful icon for the link.
> Thanks,
> Kevin
> On Wed, Jan 11, 2017 at 4:33 PM, Dan Little <theduckylittle at gmail.com>
> wrote:
>> I just went through that code and it looks like we may have deprecated
>> the configuration option of putting the layer controls next to the
>> layer title.
>> And when I looked to do a CSS hack I realized that we don't have good
>> class names there either!
>> I created this ticket to address that problem:
>> - https://github.com/geomoose/geomoose/issues/162
>> I'm going to try and get it done today but it may not make it into
>> 2.9.1 as I don't know if Jim started work on the release yet.
>> On Wed, Jan 11, 2017 at 11:48 AM, Kevin Grootendorst
>> <kgrootendorst at gmail.com> wrote:
>> > Thanks Bob and Dan for the responses.
>> > Dan - I'm okay with having all layer tools next to the layer title. In
>> fact,
>> > I will only have the metadata link tool anyway in this application.
>> > Can you elaborate on the code change(s) needed to implement this change?
>> > Thanks.
>> > Kevin
>> > On Wed, Jan 11, 2017 at 12:26 PM, Dan Little <theduckylittle at gmail.com>
>> > wrote:
>> >> You can also override the CSS for that particular tool to change the
>> >> look.  Changing the position is a bit more difficult because we have a
>> >> lot of the DOM work done in Javascript in ways that aren't easily
>> >> subclassed or overridden.
>> >> Moving the metadata tool next to the layer title will move ALL of the
>> >> On Wed, Jan 11, 2017 at 9:06 AM, Basques, Bob (CI-StPaul)
>> >> <bob.basques at ci.stpaul.mn.us> wrote:
>> >> > Kevin,
>> >> > I believe that icon is part of the GeoMOOSE icon sprite image. (one
>> >> > image
>> >> > for all the icons)
>> >> > You should be able to see the raw image (with all the icons) in it by
>> >> > right-clicking on the binocular icon and viewing the background
>> image.
>> >> > I
>> >> > did this with firefox to display the image that the icons are sourced
>> >> > from.
>> >> > You can either replace the icon sprite image with one of your own or
>> I
>> >> > believe you can substitute individual icon images in the mapbook, but
>> >> > I’ve
>> >> > not done this in quite a while myself, so someone else will need to
>> >> > chime in
>> >> > on how that’s done in the latest versions.  I do know that the more
>> >> > images
>> >> > you introduce, the slower the interface will be when loading.
>> >> > bobb
>> >> > On Jan 10, 2017, at 6:12 PM, Kevin Grootendorst
>> >> > wrote:
>> >> > Dear list,
>> >> > I would like to add a metadata link beside certain layers in my
>> catalog.
>> >> > I
>> >> > see from the demo that a link can easily be added.  I would like to
>> >> > customize the location of the link icon, and also the icon itself.
>> >> > In the attached graphic, I've enabled metadata for the layer 'DEM
>> Tile
>> >> > Index'.  However, the icon used for it is a set of binoculars and the
>> >> > link
>> >> > is located beneath the layer.  I would like to re-position the link
>> to
>> >> > be
>> >> > beside the layer name and use a different icon.
>> >> > Can someone point me to the file that contains this item so that I
>> can
>> >> > customize?  I can't seem to locate it.
>> >> > I found this site which incorporates these changes:
>> >> > http://geomoose.lyonco.org/geomoose/lyonMaindemo.html
>> >> > Thanks.
>> >> > Kevin
>> >> > <Metadata_link.PNG>_______________________________________________
>> >> > Geomoose-users mailing list
>> >> > Geomoose-users at lists.osgeo.org
>> >> > http://lists.osgeo.org/mailman/listinfo/geomoose-users
>> >> > "I've had a wonderful time, but this wasn't it." - Groucho Marx
Geomoose-users mailing listGeomoose-users at lists.osgeo.org
https://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20170125/8dc82fc5/attachment.html>
More information about the Geomoose-users mailing list
