[Geomoose-users] MS4W version 3.2.2 available
Dan Little theduckylittle at gmail.com
Fri Jul 14 08:12:28 PDT 2017
Great work Jeff! Thanks for sneaking us in there!
On Fri, Jul 14, 2017 at 10:10 AM, James Klassen <klassen.js at gmail.com>
wrote:
> Very cool.  Thanks Jeff!
> On Thu, Jul 13, 2017 at 11:12 AM, Jeff McKenna <
> jmckenna at gatewaygeomatics.com> wrote:
>> Hi all!  See below for some good news, you'll be interested that the
>> GeoMOOSE 3.0.0-beta is actually included as an option in the MS4W setup.exe
>> installer, give it a try!  :)   I also listed GM3 on the download page at
>> http://ms4w.com/download.html  -jeff
>> -------- Forwarded Message --------
>> Hello everyone,
>> MS4W version 3.2.2 is now available at http://www.ms4w.com  This
>> contains security releases of Apache, PHP, and upgrades to the MapServer
>> 7.0.6 & GDAL 2.2.1 releases.  Several changes were also made to libraries
>> for performance improvements (such as libjpeg-turbo and SQLite).  Several
>> packages were upgraded for the installer including GeoMOOSE 3.0.0-beta (new
>> backend engine, give it a try!), Mapbender 3.0.6.1 (now super fast),
>> OpenLayers 4.2.0 (when you goto the OpenLayers examples page and search for
>> "mapserver" you can find a local MS4W example).  This a substantial MS4W
>> release.  Here is the full list of changes:
>>    - upgraded MapServer and MapScript (CSharp, Java, Python, PHP) to 7.0.6
>>    - upgraded GDAL to 2.2.1 (trac ticket 111)
>>    - upgraded PHP to 5.6.31 (trac ticket 122)
>>    - upgraded Apache to 2.4.27 (trac ticket 119)
>>    - enabled OPcache PHP extension for Mapbender performance (trac ticket
>> 63)
>>    - built MapServer with support for Z geometry values (trac ticket 120)
>>    - updated cURL certificates bundle
>>    - rebuilt mod_fcgid
>>    - rebuilt Apache H264 Streaming Module
>>    - rebuilt MapCache
>>    - rebuilt TinyOWS
>>    - changed JPEG library to libjpeg-turbo (trac ticket 121)
>>    - upgraded libPNG support to 1.6.29
>>    - upgraded libTIFF support to 4.0.8 (trac ticket 114)
>>    - upgraded GeoTIFF support to SVN-trunk-20170623
>>    - rebuilt HDF4 support
>>    - upgraded HDF5 support to 1.10.1
>>    - upgraded PostgreSQL support to 9.6.3
>>    - upgraded MySQL support to 5.7.18
>>    - upgraded SQLite support to 3.19.3 (trac ticket 107)
>>    - rebuilt SpatiaLite support
>>    - upgraded OpenSSL support to 1.0.2l (trac ticket 116)
>>    - upgraded cURL support to 7.54.1
>>    - added curl.exe utility into /tools
>>    - rebuilt NetCDF support
>>    - upgraded Freetype support to 2.8
>>    - upgraded Cairo support to 1.14.10
>>    - rebuilt Poppler support
>>    - upgraded to Esri File Geodatabase 1.5 API support (trac ticket 109)
>>    - upgraded to Oracle SDK 12.2.0.1.0
>>    - upgraded PCRE support to 8.40
>>    - upgraded HarfBuzz support to 1.4.6
>>    - rebuilt libSVG support
>>    - rebuilt libSVG-Cairo support
>>    - upgraded Shapelib support to 1.4.0 (trac ticket 72)
>>    - rebuilt shp2tile utility
>>    - renamed Apache access and error log files
>> Please note that (if you are using the .zip) your server must have the
>> C++ Redistributable installed on it beforehand: execute the local file
>> /ms4w/tmp/vcredist_x86.exe
>> Please don't be afraid to also provide feedback and requests through the
>> MS4W tracker (so the comments and requests are not lost or forgotten):
>> http://www.ms4w.com/trac/
>> Thank you all for sharing your spatial information with MS4W.
>> And happy MapServing!
>> -jeff
>> Jeff McKenna
>> MapServer Consulting and Training Services
>> http://www.gatewaygeomatics.com/
>> Geomoose-users mailing list
>> Geomoose-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20170714/0678e30f/attachment.html>
More information about the Geomoose-users mailing list
