[Geomoose-users] Issues with buffer lines not displaying with select features functionality and feature reports - GM 2.9.2
Brent Fraser bfraser at geoanalytic.com
Wed Mar 15 13:49:54 PDT 2017
Mark,
Sound like Mapscript is crashing.  The demo (v2.9.2) works ok for me.
I can:
1. Display parcels
2. Click the Identify button, then click a parcel
3. The parcel info is displayed in the Identify tab, with a report link:
javascript:GeoMOOSE.startService('feature_report',%20{'PIN'%20:%20'130010001051',%20'src'%20:%20'parcels/parcels'})
4. Click the link and see the "Download File" dialog with three links:
     View in new Window/Tab
     Download
     Close this Window
5. When I click the "View ..." link the PDF is shown in a new tab with
the parcel in the PDF's map portion and the parcel info below it.
At what point do you get the "500" error?
Best Regards,
Brent Fraser
On 3/15/2017 9:25 AM, Mark Volz wrote:
> Brent,
> I am getting a 500 internal service error.  I am also getting a
> similar issue with the demo as well.
> Sincerely,
> *Mark Volz, GISP***
> *From:*Brent Fraser [mailto:bfraser at geoanalytic.com]
> *Sent:* Tuesday, March 14, 2017 5:38 PM
> *To:* Mark Volz <MarkVolz at co.lyon.mn.us>; geomoose-users at lists.osgeo.org
> *Subject:* Re: [Geomoose-users] Issues with buffer lines not
> 2.9.2
> Feature Reports are very special (and I don't think the
> feature_report.php has been changed for 2.9.2).  What specifically do
> you see (or don't see) when you try yo do an Identify->Feature Report?
> Best Regards,
> Brent Fraser
> On 3/14/2017 9:23 AM, Mark Volz wrote:
>     Brent,
>     Thank you for your reply.  It seems your thread from 2.7.1 and 2.8
>     dealt with issues when the projection the data layer, mapserver
>     map file, and geoMOOSE openlayers do not match.  In my case
>     everything should be in the same projection, which is Lyon County
>     Coordinates 103749.  I think I did everything necessary to add my
>     own projection, however it may be possible I missed a step.
>     Here is what I did to add my own projection:
>     1)Added a definition for <103749> to C:\ms4w\proj\nad\espg
>     2)Modified local_settings.ini to reference EPSG:103749, and the
>     fields used for mailing labels
>     3)Updated C:\ms4w\apps\geomoose2\conf\feature_report\parcel.xml to
>     reference my mailing labels fields
>     4)Updated the extent and projection in
>     C:\ms4w\apps\geomoose2\htdocs\geomoose\config.js
>     5)Updated the extent and projection in
>     C:\ms4w\apps\geomoose2\conf\mapbook.xml
>     6)Added EPSG103749.js to C:\ms4w\apps\geomoose2\htdocs\projections
>     7)Added EPSG103749.js to
>     C:\ms4w\apps\geomoose2\htdocs\libs\proj4js\lib\defs as well
>     8)Included script type="text/javascript"
>     src="projections/EPSG103749.js"></script> in geomoose.html
>     9)Set the mapserver .map file and all of the layers to
>     ‘init=epsg:103749’
>     Everything appears to work except for feature reports and the
>     polygon outline displaying the buffer on select features.
>     Thank You
>     Sincerely,
>     *Mark Volz, GISP*
>     *Sent:* Monday, March 13, 2017 6:26 PM
>     <mailto:MarkVolz at co.lyon.mn.us>; geomoose-users at lists.osgeo.org
>     <mailto:geomoose-users at lists.osgeo.org>
>     - GM 2.9.2
>     Mark,
>       I did some testing some time ago on v2.7.1 and v2.8.  The
>     behaviors I found may be related to what you are seeing. Have a
>     look at the thread
>     http://lists.osgeo.org/pipermail/geomoose-users/2015-July/005735.html
>     Best Regards,
>     Brent Fraser
>     On 3/13/2017 1:36 PM, Mark Volz wrote:
>         Hello,
>         I am still having issues trying to get the feature report and
>         buffer on selected features functionality to work on my map.
>         I am specifically wondering if anyone has had any success
>         using a projection other than EPSG:3857.
>         Buffers:
>         At GeoMOOSE 2.9.2 the select feature function uses query.php.
>         However on an older 2.6 application I noticed the select
>         feature function used select.php instead.
>         *Do I need select.php to draw buffers in the select feature
>         function?
>         *select.php attempts to create a spatial lite .db file.
>         However, I cannot get this file to open in Mapserver
>         *I cannot get the mailing labels to work using select.php
>         Feature Reports:
>         I am also having issues with the feature report
>         functionality.  Is the feature report dependent on a certain
>         projection?
>         Anyways, if anyone has had any luck configuring GM 2.9.2 with
>         a different projection please let me know.
>         Thank You!
>         Sincerely,
>         Mark Volz
>         _______________________________________________
>         Geomoose-users mailing list
>         Geomoose-users at lists.osgeo.org
>         <mailto:Geomoose-users at lists.osgeo.org>
>         https://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20170315/74309cca/attachment.html>
More information about the Geomoose-users mailing list
