[Geomoose-users] TR: [GM 3.2] Identify Error
Dan Little theduckylittle at gmail.com
Tue Aug 21 12:13:47 PDT 2018
Can you try dropping the query-as attribute from your layer? I haven't
tested query-as when it's referring to the same layer.
On Mon, Aug 20, 2018 at 7:52 AM Renaud LAIRE <
r.laire at parc-livradois-forez.org> wrote:
> Hi all.
> I’m using geomoose 2.9, and now i try to migrate to geomoose 3.2
> I’ve already transferred my data and it’s work great.
> But when i try tu use the identify, i ve no result (blank screen on tab) ,
> with the error on console ‘TypeError: Cannot read property 'templates' of
> null’
> The mapbook :
> *<map-source name="adm" type="mapserver" up="true" down="true"
> title="Limites Communales">*
> *        <file>./maps/adm.map</file>*
> *        <layer name="com" status="on" query-as="adm/com">*
> *            <template name="identify"
> src="./templates/adm/identify_commune.html" />*
> *        </layer>*
> *    </map-source>*
> The mapfile :
> *LAYER  *
> *    TYPE polygon*
> *      NAME "com"*
> *                  CONNECTIONTYPE postgis*
> *       CONNECTION "host=localhost user=-----  password=-----
>  dbname=bdgeo"*
> *       DATA "geom from admin.communes as foo USING UNIQUE id USING
> SRID=2154"*
> *    STATUS OFF*
> *                  TRANSPARENCY  75*
> And the file is well open when i try
> http://_IP_/desktop/templates/adm/identify_commune.html
> Where i ‘ve forget something ?
> Any hints ?
> Thanks,
> *Renaud LAIRE*
> *PNR Livradois Forez*
> Maison du Parc
> 63880 ST Gervais sous Meymont
> 04 73 95 57 57
> Geomoose-users mailing list
> Geomoose-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20180821/ce487d2a/attachment.html>
More information about the Geomoose-users mailing list
