[Geomoose-users] Template / Results Issues
Jeff McKenna jmckenna at gatewaygeomatics.com
Wed Feb 7 06:45:10 PST 2018
Hi Tanya,
I've tested with the included "Test International Characters" layer that
is included in the packaged mapbook.xml by default, using MS4W version 3.2.3
I was able to get your exact same error through an identify on that layer.
I fixed this by making sure to specify "{{ properties.FIELDNAME }}" in
my mapbook.xml (at first I had just "{{ FIELDNAME }}").  Here is the
working section:
https://gist.github.com/anonymous/945d1987942ff34fbc53d253c8cd20b3
Maybe your issue is similar.
-jeff
Jeff McKenna
MapServer Consulting and Training Services
http://www.gatewaygeomatics.com/
On 2018-02-07 2:27 AM, TC Haddad wrote:
> hi all,
> I've just been testing 3.1 with some local data, and have a weird issue
> with displaying the results from Identify, Select, and Search.
> I'm getting correct number of records and fields returning for each item
> clicked, selected, or found via a search, but result contents all
> display as "???".
> example: http://bit.ly/2FS8ySS
> I feel like I'm missing something really basic - any ideas why my
> templates aren't correctly populating?
More information about the Geomoose-users mailing list
