[Geomoose-users] GeoMoose Demo, 3.2.0 and Projection Issue
Dan Little theduckylittle at gmail.com
Fri Jun 1 06:11:25 PDT 2018
At this juncture GeoMoose 3.X does not support configuring the maps in
projections other than Web Mercator.  The folks who funded the development
of version 3 had been using Web Mercator exclusively and reprojecting their
source data.
Adding the projection with app.addProjection only adds a projection
configuration to the "projection database" that is stored on the client.
Which makes it possible to interact with that projection.  Changing
geomoose_globals and the parcel boundary in app.js will not reconfigure the
base map's projection.
If supporting a basemap in a different projection is a high-priority for
yourself or others than we can certainly chat about what it would take to
add that support.
On Wed, May 30, 2018 at 12:23 PM Carrie Quast <Carrie.Quast at co.brown.mn.us>
wrote:
> I am working with GeoMoose 3.2.0, using the demo data and working on
> getting a usable application for my county.
> The problem is, projection isn’t working.  I’ve double checked the app.js
> file and it is correct for my projection ( app.addProjection ({ ref:
> ‘EPSG:26915’, etc etc)
> I’ve double checked that the projection is right in my
> geomoose_globals.map:  “Init=epsg:26915”
> I’ve set my extents in the app.js to the parcel boundary
> (331521.859693,4884856.976580, etc, etc.) – and the extents work, but
> nothing is there.
> The application is still placing my parcels at the original default
> projection – I’m assuming its web Mercator per the gm3 How-To Configure the
> Coordinate Display.
> What am I missing?
> Thank You – Carrie Quast
> ________________________________
> Carrie Quast, GIS / Web Administrator
> Phone: 507-233-6633 Ext. 633
> Geomoose-users mailing list
> Geomoose-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20180601/99483f0d/attachment.html>
More information about the Geomoose-users mailing list
