[Geomoose-users] Highlight Parcel and runtime substitution
Colas, Scott Scott.Colas at ct.gov
Wed Nov 28 12:19:11 PST 2018
Thanks Dan,
After tweaking the parameters in query.php will my parameter be available in my map file so I can filter on the parameter?
-Scott
From: Dan Little [mailto:theduckylittle at gmail.com]
Sent: Wednesday, November 28, 2018 10:47 AM
To: Colas, Scott
Cc: GeoMOOSE Users List
Subject: Re: [Geomoose-users] Highlight Parcel and runtime substitution
Hi Scott,
Is this a GeoMoose 2.9-based application? Looks like it if you're using "GeoMOOSE...".
Check out query.php and the various services that use it.  You should be able to either make your own derivative version of the service, or tweak the query.php input parameters to get the result you want using you mapbook.
Cheers.
On Wed, Nov 28, 2018 at 8:19 AM Colas, Scott <Scott.Colas at ct.gov<mailto:Scott.Colas at ct.gov>> wrote:
Hello All,
I have  a service that does a search for a project. My goal is to zoom to this project and highlight. I can zoom to this project using GeoMOOSE.zoomToPointsList, but I cannot highlight the area.
In my map file I am using filterItem and filter.
How do I send my variable from a service to a map file so I can filter on this variable?
  LAYER
      INCLUDE "../../db_connection"
    DATA "geometry3857 FROM [ASSETS].[ProjectWorkAreas] USING UNIQUE AreaID USING SRID=3857"
    PROCESSING "NATIVE_FILTER=([IsProposed] = 0)"
       LABELITEM "ProjectNumber"
       CLASSITEM "PROJ_CURRENT_PHASE"
       NAME "LocalhProjectPolygons"
       TYPE POLYGON
       VALIDATION
        "PROJECTNUM" "[0-9]+"
       END
FILTERITEM "ProjectNumber"
       FILTER "%PROJECTNUM%"
       CLASS
              NAME "05 Construction"
              EXPRESSION "05_Construction"
              TEXT "%PROJECTNUM%"
              LABEL
                     MAXSCALEDENOM 28000
                     FONT "vera_sans"
                     SIZE 10
                     ALIGN CENTER
                     COLOR 255 0 0
Thank you,
-Scott
Geomoose-users mailing list
Geomoose-users at lists.osgeo.org<mailto:Geomoose-users at lists.osgeo.org>
https://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20181128/21d35481/attachment.html>
More information about the Geomoose-users mailing list
