[Geomoose-users] Geomoose 3 onclick action
Dan Little theduckylittle at gmail.com
Tue Feb 5 05:43:48 PST 2019
GeoJson is the easiest. Go forth and {}.
On Fri, Dec 14, 2018 at 9:14 AM Jim Klassen <klassen.js at gmail.com> wrote:
> Short of Little saying otherwise, I'm pretty sure GeoMoose 3 is using
> GeoJSON as it's internal representation of features, so my guess is GeoJSON
> is the simplest point format.
> On 12/13/2018 11:41 AM, Reynolds, Michael J. (MNIT) wrote:
> This seemed to work…  though I'm wondering why I couldn't get it to work
> until I passed in_point to geojson_point.  Is there a simpler point format
> allowed?
> /** projects incoming point coordinates and projection to target
> * projection and passes to zoomTo function.
> * @param in_point - point coordinate array [x, y]
> * @param projection - string 'EPSG:####'
> * @param zoom - integer zoom level
>  * @returns zooms to coordinate location and zoom level
>  * Search Template usage example
> * <a onClick="projectZoomTo([{{ geometry.coordinates.0 }},{{
> geometry.coordinates.1 }}], 'EPSG:3857',16)" class="zoomto-link">
> *            <i class="fa fa-search"></i>
>  *            {{ properties.equipmentname|blank> }}
> * </a>
> function projectZoomTo(in_point, projection, zoom) {
>                   geojson_point = [{
>                                                   "type": "Feature",
>                                                   "geometry": {
>                                                     "type": "Point",
>                                                     "coordinates":
> in_point
>                   var new_point = gm3.util.projectFeatures(geojson_point,
> projection, 'EPSG:4326')[0];
>                   return
> app.zoomTo(new_point.geometry.coordinates[0],new_point.geometry.coordinates[1],
> zoom);
> *From:* Jim Klassen [mailto:klassen.js at gmail.com <klassen.js at gmail.com>]
> *Sent:* Wednesday, November 28, 2018 11:55 AM
> *To:* Reynolds, Michael J. (MNIT) <mike.reynolds at state.mn.us>
> *Cc:* GeoMOOSE Users List <geomoose-users at lists.osgeo.org>
> *Subject:* Re: [Geomoose-users] Geomoose 3 onclick action
> It looks like app.zoomToExtent() takes an extent and projection and
> app.zoomTo() takes a point (in lat/lon), and zoom level, but no
> projection.  This seems like it might be a bit on an oversight, but in the
> meantime gm3.util.projectFeatures() is available from services.  Paring
> that with app.zoomTo(point, zoom_level) looks like it would work.
> You could do this in the template directly or add a helper function in
> your app.js.
> Say something like (untested):
> function myZoomTo(in_point, projection, zoom) {
>   var point = gm3.util.projectFeatures([point], projection,
> 'EPSG:4326')[0];
>   return app.zoomTo(point, zoom);
> then call it from the template as:
> myZoomTo({geometry.coordinates: [x, y]}, 'EPSG:26915', 16);
> I'm not sure that using the global space for myZoomTo is best practice,
> but just an idea to get started.
> I am also remembering something now about the search templates being able
> to reproject points, but it looks like that is using properties.boundedBy
> and app.zoomToExtent, so that might not apply.
> On 11/28/2018 11:18 AM, Reynolds, Michael J. (MNIT) wrote:
> The onClick would be in a search template used for rendering search
> results.  Once rendered and displayed to the user, the user could click the
> <a> and the onClick would execute the function to zoom to the location.
> <div class="search-result">
>                 <div class="search-label">
>                                 {{ properties.name }}     </div>
>                 <div class="search-action">
>                                 <div style="padding: 2px">
>                                                 <a
> onclick='app.zoomToCoordinates([{{ geometry.coordinates.0 }},{{
> geometry.coordinates.1 }}], 26915, 16)' class="zoomto-link">
>        <i
>        Zoom!
>                                                 </a>
>                                 </div>
>                 </div>
> </div>
> *From:* James Klassen [mailto:klassen.js at gmail.com <klassen.js at gmail.com>]
> *Sent:* Wednesday, November 28, 2018 10:44 AM
> I'm lost.  Where is the onClick coming from (DOM element, general
> description, ...)?
> I know you can create a service that asks the user to click a point on the
> map and returns the coordinate, etc.  You can call the app.* from the HTML
> returned by the service rendering template (and maybe even earlier) without
> worrying about react/dispatch/etc.
> I am working on a jump to USNG coordinate service in a branch on my fork
> (klassenjs/gm3) that does both of the above.
> On Tue, Nov 27, 2018, 06:39 Reynolds, Michael J. (MNIT) <
> mike.reynolds at state.mn.us wrote:
> We're trying to create an onClick() event that passes coordinates, srid,
> and zoom level in and moves the map to that location.
> It seems like the onClick event would need to create an action loaded with
> the parameters, register and then dispatch or run it, so would that be a
> function we create in our app's app.js?
> Plus we would then need to create the zoom action which we would like to
> transform the coordinates from in-srid to web Mercator and then move the
> map.  Are Proj and mapActions available to actions at runtime?
> onClick => app.zoomToCoordinates() => dispatch ZoomToCoordinates action to
> transform coordinates and move map.
> There's a gm3 zoomTo() function now but it expects lat,lon.  We're not
> currently modifying any of the core geomoose 3 code and hoping to be able
> to add this modification to our app's part of the code.
> Open to any ideas, even scrapping this procedure with a shorter one if
> there's a way to control the map without dispatching an action but that
> would mean the js function somehow needs access to the app Proj library and
> map object. Right?
> *Michael Reynolds*
> Geomoose-users mailing list
> Geomoose-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20190205/547d75a9/attachment-0001.html>
More information about the Geomoose-users mailing list
