[Geomoose-users] GeoMOOSE Printing with SSL?
Mark Volz MarkVolz at co.lyon.mn.us
Tue Mar 12 12:57:19 PDT 2019
Jim,
Thank you for your feedback.
I did check that all the requests are https://.
Also, I did update the server_name to geomoose.lyonco.org:443.  Should that be okay?
How can I check if php does not like my certificate, and if needed make php trust the certificate?   And yes I am using MS4W which you said may cause issue.
Thanks
Sincerely,
Mark Volz, GISP
Lyon County GIS Coordinator
Sent: Tuesday, March 12, 2019 12:37 PM
To: Mark Volz <MarkVolz at co.lyon.mn.us>
Cc: GeoMOOSE Users List <geomoose-users at lists.osgeo.org>
Subject: Re: [Geomoose-users] GeoMOOSE Printing with SSL?
SWHHS/LYON/LINCOLN COUNTY SECURITY NOTICE:
This email originated from an external sender. Exercise caution before clicking on any links or attachments and consider whether you know the sender. For more information please contact IT support.
Some thoughts:
Make sure all the requests in the browser are to https services.  http ones will likely be blocked in some contexts if the main page is http.  In any case you would get a mixed content warning.
You need to use full domain names (whatever matches the ssl certificate) with https not ip adresses because ip addresses won't match the server certificate.
You might also have an issue with the ssl certificate authority not being trusted by PHP (especially the PHP version included with some versions of MS4W). I remember seeing something about that awhile ago but I don't remember the details.
On Tue, Mar 12, 2019, 10:03 Mark Volz <MarkVolz at co.lyon.mn.us<mailto:MarkVolz at co.lyon.mn.us>> wrote:
Hello,
After updating my server to SSL I am having issues printing maps in GeoMOOSE 2.9.3.  At this point in time I can get GeoMOOSE to present a map to the end user and display the background.  However, I cannot see any active layers such as parcels.   Please let me know if anyone has a thought as to why the active layers are not printing.
Thanks
P.S.  Originally I could not get anything to work on the client side after switching to SSL.  On the client side the Print Map displays “Loading…”  forever.  On the server side a PDF is generated in the temp folder, however only the template and background map display and the active layers such as parcels do not display.  I changed server_name to use my ip address and port 443 so now my end users can see the pdf template and background, but still not the parcel layer.  As of right now the background layer will work in both http and https mode.
Sincerely,
Mark Volz, GISP
504 Fairgrounds Rd<https://linkprotect.cudasvc.com/url?a=https%3a%2f%2fwww.google.com%2fmaps%2f%3fdaddr%3d504%2520Fairgrounds%2520Rd%2c%2520Marshall%2c%2520MN%252056258%3fz%3d6&c=E,1,mTQU2ON9bb_CVbDyOLsQN45Ad_qKRqMb9ACvXsviPg7KhQzOkcK5ZhokS5-Pkl5Bnr4U6uPs_ooih20JlUnhs5_OP6ZLU0YBhW2AlQebZWvuH23k&typo=1>
Marshall, MN 56258<https://linkprotect.cudasvc.com/url?a=https%3a%2f%2fwww.google.com%2fmaps%2f%3fdaddr%3d504%2520Fairgrounds%2520Rd%2c%2520Marshall%2c%2520MN%252056258%3fz%3d6&c=E,1,ILeg6P_P9-xPMxha_q3NUqoPP3v-wKwKziZ6zeIqDq4T7EUMjQo7fSnFk6mDG0v1cRWkdftL4TxcToFUC8Qh-DBkD5-Ik9X8otzuagfgsg5CgtI-RSl64xgpqT9S&typo=1>
Ph:  (507) 532-8218
Fax: (507) 532-8217
http://lyonco.org/<https://linkprotect.cudasvc.com/url?a=http%3a%2f%2flyonco.org%2f&c=E,1,q3lHUmLn5wM3BeiKv6cd8VmSxvoGvRnCS6wIKkmkl7-tn7RZAl_X_HDHACZIaTfrCjwwsxmBhD2hRR_vPyjb3BI5X4qZeIM9bn9bUlklh1ODjBk,&typo=1>
http://geomoose.lyonco.org/<https://linkprotect.cudasvc.com/url?a=http%3a%2f%2fgeomoose.lyonco.org%2f&c=E,1,kx97pZJ7xI0XBJpPZ46tFr4Sbvyfwi5KG9pv9GwoA6nQd9xbQDx1Ux_cAwKiGVvQ_m0wM7cMERB9tBc68RJreUQkRR40Jn3p2ovcxO_mWf0,&typo=1>
Geomoose-users mailing list
Geomoose-users at lists.osgeo.org<mailto:Geomoose-users at lists.osgeo.org>
https://lists.osgeo.org/mailman/listinfo/geomoose-users<https://linkprotect.cudasvc.com/url?a=https%3a%2f%2flists.osgeo.org%2fmailman%2flistinfo%2fgeomoose-users&c=E,1,7NU89jo82JmJocFfkt3wzJ7URLYdK5TXdhIBg2997LMGcDTNt4GVK8n6YkxeUX6cIQkMqbxesQScSRhSa6iB4rcAeVChI3UI07kU8Nd1bQt3MEpZRcU,&typo=1>
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20190312/8d9a3247/attachment.html>
More information about the Geomoose-users mailing list
