[Geomoose-users] Converting from ags to raster map file
James Klassen klassen.js at gmail.com
Wed Mar 13 11:32:54 PDT 2019
Off the top of my head, you will need to create a GDAL vrt file that points
to the AGS service and then point the mapfile at the vrt file.
Sorry, I don't have time to look up the details today.
On Wed, Mar 13, 2019, 08:05 Colas, Scott <Scott.Colas at ct.gov> wrote:
> Hi James,
> Thank you for your response. What do you think I should change my
> CONNECTIONTYPE to? .
> Also my goal is to combine two layers in one map file and make each layer
> visible at different zoom levels using MAXSCALEDENOM AND MINSCALEDENOM. Is
> it possible to accomplish this only using the mapbook?
> MAP
>        INCLUDE "../../geomoose_globals.map"
>        WEB
>               INCLUDE "../../temp_directory.map"
>               LOG "mapserver.log"
>               METADATA
>                      "ows_title" "UCONN 2016 Ortho Imagery"
>                      "ows_srs" "EPSG:3857"
>                      "ows_enable_request" "*"
>               END
>        END
>        PROJECTION
>               "init=epsg:3857"
>        END
>        LAYER
>               NAME "layer1"
>               CONNECTION "
> http://services.arcgisonline.com/arcgis/rest/services/World_Imagery/MapServer/WMTS/1.0.0/WMTSCapabilities.xml
>               CONNECTIONTYPE WMS
>               TYPE RASTER
>               CLASS
>                            MAXSCALEDENOM 13000
>               END
>               METADATA
>                      "wms_srs" "EPSG:3857"
>                      "wms_name" "Imagery"
>                      "wms_server_version" "1.1.1"
>                      "wms_format" "image/jpeg"
>               END
>        END
>        LAYER
>               NAME "layer2"
>               CONNECTION "
> http://wms.onterrasystems.com/WMSService.svc/a48a7531547e4367b28a96ab03507fd4/WMSLatLon
>               CONNECTIONTYPE WMS
>               TYPE RASTER
>               CLASS
>                            MINSCALEDENOM 13001
>               END
>               METADATA
>                      "wms_name" "OnTerraWMS"
>                      "wms_style" "Road"
>               END
>        END
> END’
> Thank you,
> Scott
> *From:* James Klassen [mailto:klassen.js at gmail.com]
> *Sent:* Tuesday, March 12, 2019 4:37 PM
> *To:* Colas, Scott
> *Cc:* GeoMOOSE Users List
> *Subject:* Re: [Geomoose-users] Converting from ags to raster map file
> I'm going to guess here that CONNECTIONTYPE WMS in the mapfile isn't
> correct for an ArcGIS REST endpoint.
> On Tue, Mar 12, 2019, 13:57 Colas, Scott <Scott.Colas at ct.gov> wrote:
> Hello All,
> I am having trouble converting a ags map into a raster map file. I took
> the URL from the old map source and put it inside of a layer but it’s not
> loading.
> Old source: Working
>   <map-source name="agsimagery" type="ags" reference="false" opacity=".3">
>     <url>
> http://services.arcgisonline.com/ArcGIS/rest/services/World_Imagery/MapServer/export
> </url>
>     <layer name="Imagery" reference="false" />
>     <param name="FORMAT" value="png"/>
>   </map-source>
> New source and layer: Not working
>   <map-source name="uconnOrtho2012" type="mapserver" >
>     <file>./ct/wms/uconnOrtho2012.map</file>
>     <layer name="Imagery" />
>   </map-source>
> MAP
>        WEB
>               METADATA
>                      'ows_title' 'UCONN 2012 Ortho imagery'
>                      'ows_srs' 'EPSG:3857'
>                      'ows_enable_request' '*'
>               END
>        END
>        PROJECTION
>               "init=epsg:3857"
>        END
>        LAYER
>               STATUS ON
>               NAME "Imagery"
>               CONNECTION "
>               CONNECTIONTYPE WMS
>               TYPE RASTER
>               METADATA
>                      "wms_enable_request" "*"
>                      "wms_format" "image/png"
>               END
>        END
> END
> Thank you
> -Scott
> Geomoose-users mailing list
> Geomoose-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20190313/ac2025f0/attachment-0001.html>
More information about the Geomoose-users mailing list
