[Geomoose-users] Add a language to GeoMoose
Eli Adam eadam at co.lincoln.or.us
Mon Dec 7 06:29:17 PST 2020
Hi Flavio,
Adding additional languages is great!  Can you open a Github issue
with it.json here, https://github.com/geomoose/gm3/issues?
It looks like placement of the language file has come up before,
https://github.com/geomoose/gm3/issues/544
And maybe we should actively call for additional translations there too!
Best regards, Eli
On Sun, Nov 29, 2020 at 11:43 PM flavio rigolon
<flavio.rigolon at gmail.com> wrote:
> Hi all,
>  I'm using GeoMoose 3.6.2 and I've added my own "it.json" (italian language).
> The default languages are stored in
> "/srv/geomoose/gm3-example/htdocs/geomoose/src/gm3/lang/" but
> following the instruction [1] is implied but not explicitly said that
> we have to copy the. json file in the "home" directory (i.e.
> "/srv/geomoose/gm3-example/htdocs/desktop"). So, in my case I've set
> the "app.js" file like this:
> var app = new gm3.Application({
> mapserver_url: CONFIG.mapserver_url,
> mapfile_root: CONFIG.mapfile_root,
> map: {
> scaleLine: {
> enabled: true,
> //    units: 'imperial'
> units: 'metric'
> lang: {
> it: './it.json',
> and it works fine.
> Is it the case of edit the page [1] to explicitly point where the
> .json file must be? (I think there is also a trivial typo error in the
> page title: "...langauge" should be "...language").
> I've translated the .json file in italian; do you think it could be
> share to give a base point for other italian users like the es.json
> one for spanish?
> my 2 cents
> best regards
> flavio
> [1] https://geomoose.github.io/gm3/howto/add-a-language.html
> /"\  ASCII Ribbon Campaign
> \ /  Respect for low technology.
>  X  Keep e-mail messages readable by any computer system.
> / \  Keep it ASCII.
> Geomoose-users mailing list
> Geomoose-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geomoose-users
More information about the Geomoose-users mailing list
