[Geomoose-users] GeoMoose 3 - Select
Christopher Hughes chughes at co.lincoln.or.us
Fri Jan 10 13:35:24 PST 2020
For geomoose 3, is there a way to specify which layers you can select
rather than just setting
the default layer and being able to select all layers you've set to be
selectable? I'd like to create
a select tool for each of the layers I want to select (like you can for
searches), but if I do that now
you'd still be able to switch to a different layer in the tool. Relatedly,
is there a way to remove the
'Select from' dropdown box so it just uses the default layer you set in the
service?
Thanks,
Chris
Chris Hughes
GIS Analyst
Lincoln County Surveyor Department
880 NE 7th St. l Newport, OR 97365
Tel: (541) 574 1283
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20200110/53f06b3a/attachment.html>
More information about the Geomoose-users mailing list
