[Geomoose-users] Fwd: Re: Identify with scale/resolution dependent layers
Eli Adam eadam at co.lincoln.or.us
Fri Jul 24 11:45:38 PDT 2020
The option to identify (or select) on non-visible (due to scale) or
off layers seems useful so long as it is configurable.
Sometimes it is nice to give a point in polygon report that gives the
water company, electric company, gas company, cable company, garbage
company, and 20 other districts without displaying all those districts
which have very little display value.
Personally I like the select tool to be focused on a target layer and
get the results from only the layer that I targeted for selection.  I
can see how there could be a use case for select all the layers,
although I wouldn't use that.
Best regards, Eli
On Thu, Jul 23, 2020 at 10:13 AM Brent Fraser <bfraser at geoanalytic.com> wrote:
> ________________________________
> From: "Brent Fraser" <bfraser at geoanalytic.com>
> Sent: 7/23/20 10:58 AM
> To: "James Klassen" <klassen.js at gmail.com>
> Subject: Re: [Geomoose-users] Identify with scale/resolution dependent layers
> Interesting, I hadn't considered what would happen if the user did an Identify on a visible feature, then used the ZoomTo feature option, then it became invisible due to a resolution setting.  Rather unsettling!
> My original problem was with the following workflow:
> - user zooms in map
> - layer 1 is on and visible (no resolution restriction), layer 2 is on but NOT visible due to resolution restriction
> - user does an Identify operations
> - results are returned for layer 1 AND layer 2 (even though layer 2 is not visible)
> In my opinion there should be no results for layer 2.  Making this behaviour opt-in is a good solution.  Not sure if it should be an attribute on the <mapsource> (where the *resolution is set) or the <template type="identify"> (where identify is enabled).
> From: James Klassen <klassen.js at gmail.com>
> Sent: 7/23/20 10:24 AM
> To: Brent Fraser <bfraser at geoanalytic.com>
> Cc: GeoMoose Users <geomoose-users at lists.osgeo.org>
> My options:
> Select almost has to work independent of scale (You can zoom in the middle of a select, what happens then?  Plus the user chooses the layer they are selecting on so they have control there.)
> Identify should work with what is visible.  To me identify is the user asking "what is this?" which doesn't make much sense to me if the "this" is hidden and the user wouldn't have known it was there to query.  If we change this behavior we should probably do so as an opt in, otherwise this could be considered a breaking change if someone was relying on the old behavior.  (I would update the examples to opt-in).
> On Thu, Jul 23, 2020, 11:16 Brent Fraser <bfraser at geoanalytic.com> wrote:
>> Hi All,
>> Should Identify and Select (and maybe Search? ) work on layers that are not displayed due to a scale restriction (e.g. minresolution=20)?  They currently do in v3.6.3-beta.
>> Thanks for opinions!
>> Brent Fraser
>> Geomoose-users mailing list
>> Geomoose-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/geomoose-users
More information about the Geomoose-users mailing list
