[Geomoose-users] [GeoMOOSE-users] WMS tiled layers
Dan Little
theduckylittle at gmail.com
Thu Feb 3 07:41:48 PST 2022
Totally understandable. However, WMS is not necessarily the best way to do
that. If you do not want to worry about setting up MapCache you can use
MapServer's Tile mode:
- https://mapserver.org/output/tile_mode.html
On Thu, Feb 3, 2022 at 9:37 AM Mark Volz <MarkVolz at co.lyon.mn.us> wrote:
> Dan,
> Thank you for letting me know.
> I just wanted to add a service that is WMS only and have GeoMOOSE call
> chunks of WMS separately when panning so that the imagery would seem like
> it is more responsive than seeing a blank image until the pan is compute…
> if that makes sense… I can also use Map Cache to convert the source WMS
> service to WMST.
> Thanks!
> Sincerely,
> *Mark Volz, GISP*
> *Lyon County GIS Coordinator*
> Ph: (507) 532-8218
> *From:* Dan Little <theduckylittle at gmail.com>
> *Sent:* Thursday, February 3, 2022 9:24 AM
> *To:* Mark Volz <MarkVolz at co.lyon.mn.us>
> *Cc:* geomoose-users at lists.osgeo.org
> *Subject:* Re: [Geomoose-users] WMS tiled layers
> Caution:
> This email was sent from an external account. If you were expecting an
> internal email you would not see this notice. Please exercise caution
> before clicking on any links. Report any suspicious email to the Help Desk.
> Question Everything: Were you expecting this email?
> It does not support them in that format, however, you can use WMTS in
> order to do the same thing.
> On Mon, Jan 31, 2022 at 9:13 AM Mark Volz <MarkVolz at co.lyon.mn.us> wrote:
> Hello,
> Can GeoMOOSE 3.x still request WMS layers in tiles? That way I can have
> images load as I pan around on the map.
> Thanks!
> <map-source name="mngeo" type="wms" tiled="true" width="512" height="512"
> buffer="false" transition_Effect="map-resize">
> Sincerely,
> *Mark Volz, GISP*
> Ph: (507) 532-8218
> Geomoose-users mailing list
> Geomoose-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geomoose-users
> <https://linkprotect.cudasvc.com/url?a=https%3a%2f%2flists.osgeo.org%2fmailman%2flistinfo%2fgeomoose-users&c=E,1,hP_XByRgRcLomlZ_jRdUoM7AehNafFyJE8oiOUB8tZ9dI9rHVLX3eOT2XKWBystmm_y-5zVwodzsZMPbcgJgBPqf_zf2fjMU-WoK8o-iE1IWQgh5vj6qA-4ACfY,&typo=1>
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20220203/03bf9b6d/attachment.html>
More information about the Geomoose-users
