[Geomoose-users] adding examples to our searches
Basques, Bob (CI-StPaul) bob.basques at ci.stpaul.mn.us
Mon Feb 28 15:02:38 PST 2022
Nice!!
Bobb
My machine - - - PW19-S295-C024
From: Geomoose-users <geomoose-users-bounces at lists.osgeo.org> On Behalf Of Christopher Hughes
Sent: Monday, February 28, 2022 5:01 PM
To: Mark Volz <MarkVolz at co.lyon.mn.us>
Cc: geomoose-users at lists.osgeo.org
Subject: Re: [Geomoose-users] adding examples to our searches
Think Before You Click: This email originated outside our organization.
I don't think this is currently an option, though I think it's definitely a good idea.
I think I figured out a way to do this, though I needed to edit the source code and rebuild the javascript.
I added a line of code at line 74 of text.js<https://github.com/geomoose/gm3/blob/main/src/gm3/components/serviceInputs/text.js> (note that I named it 'example'):
            <div className='service-input'>
                <label htmlFor={ 'input-' + id }>{ this.props.field.label } </label>
                <example htmlFor={ 'input-' + id }>{ this.props.field.example }</example>
                <input onChange={this.onChange} value={this.state.value} type="text" id={ 'input-' + id}></input>
            </div>
After rebuilding the javascript I was then able to add examples to searches in the app.js file:
            {type: 'text', label: 'Owner Name', example: '(i.e. Hughes)', name: 'OwnName'},
            {type: 'text', label: 'Situs Address', example: '(i.e. 10770 ELK CITY RD)', name: 'SitusAll'},
            {type: 'text', label: 'Map Taxlot', example: '(i.e. 11-10-00-00-00300-00)', name: 'ParcelID'},
            {type: 'text', label: 'Account Number', name: 'PropertyId'}
You can then modify your site.css to decrease the size.
This was my end result:
[cid:image001.png at 01D82CC4.FCC8CD60]
Hope this helps,
Chris
On Thu, Feb 10, 2022 at 5:46 AM Mark Volz <MarkVolz at co.lyon.mn.us<mailto:MarkVolz at co.lyon.mn.us>> wrote:
Hello,
I can change the titles for each field in the search tool.  Is it possible to add a line under the title that has an example of the search.  For Example:
On the first line with the current font : “Parcel ID”
On the next line with a smaller font: “Example 01-001001-0”
This will help users understand which format they should use when they perform a search.
Thank You!
Sincerely,
Mark Volz, GISP
Lyon County GIS Coordinator
Ph:  (507) 532-8218
Geomoose-users mailing list
Geomoose-users at lists.osgeo.org<mailto:Geomoose-users at lists.osgeo.org>
https://lists.osgeo.org/mailman/listinfo/geomoose-users
Chris Hughes
GIS Analyst
Lincoln County Surveyor Department
880 NE 7th St. l Newport, OR 97365
Tel: (541) 574 1283
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20220228/25602b5a/attachment-0001.html>
Type: image/png
Desc: image001.png
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20220228/25602b5a/attachment-0001.png>
More information about the Geomoose-users mailing list
