[GeoNode-devel] Using HTTPS Geoserver with Geonode.
Francesco Bartoli xbartolone at gmail.com
Sat Dec 5 07:44:46 PST 2015
if your geonode instance is running within Apache then you have to instruct its httpd process to do not verify certificate of GeoServer in the proxy pass directive [1]. Otherwise if you have to verify it for security reasons then you should add its CA to the trusted store of CAs [2].
Hope this helps
Francesco
[1] https://httpd.apache.org/docs/trunk/mod/mod_ssl.html#sslproxyverify
[2] https://httpd.apache.org/docs/trunk/mod/mod_ssl.html#sslproxycacertificatepath
Il giorno 04/dic/2015, alle ore 17:24, mdoakes42 at verizon.net ha scritto:
> Summary:  Using HTTPS Geoserver with Geonode.
> I just finished installing geonode on a local test box and the app comes up fine.   I have a remote GEOSERVER that is HTTPS enabled.   When I try to upload layers I get an error in the server regarding SSL_GET_SERVER_CERTIFICATE: certificate verify failed.
> Can Geonode be configured so that I can communicate with an HTTPS enabled Geoserver.    (In Geoserver we have to present a certificate (PKI) in order to login).   On the geoserver side we basically have this installed
> http://docs.geoserver.org/latest/en/user/security/tutorials/cert/
> geonode-devel mailing list
> geonode-devel at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geonode-devel
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20151205/5b05cf96/attachment.html>
More information about the geonode-devel mailing list
