[GeoNode-devel] Using HTTPS Geoserver with Geonode.
Jeffrey Johnson ortelius at gmail.com
Mon Dec 7 20:41:20 PST 2015
Yes, this looks like the right place. A PR against the docs from someone
would be very appreciated.
On Mon, Dec 7, 2015 at 9:02 PM, Francesco Bartoli <xbartolone at gmail.com>
wrote:
> Hi Jeff,
> agreed, it makes sense. Maybe here in these two places?
> https://github.com/GeoNode/geonode/blob/master/docs/tutorials/install_and_admin/geonode_install/setup_configure_httpd.txt
> https://github.com/GeoNode/geonode/blob/master/docs/tutorials/install_and_admin/setup_on_centos/install_base_httpd.txt
> Ciao
> Francesco
> Il giorno 07/dic/2015, alle ore 05:16, Jeffrey Johnson <ortelius at gmail.com>
> ha scritto:
> Might be good to add something about this topic to the docs somewhere.
> On Sat, Dec 5, 2015 at 10:44 PM, Francesco Bartoli <xbartolone at gmail.com>
> wrote:
>> Hi,
>> if your geonode instance is running within Apache then you have to
>> instruct its httpd process to do not verify certificate of GeoServer in the
>> proxy pass directive [1]. Otherwise if you have to verify it for security
>> reasons then you should add its CA to the trusted store of CAs [2].
>> Hope this helps
>> Francesco
>> [1] https://httpd.apache.org/docs/trunk/mod/mod_ssl.html#sslproxyverify
>> [2]
>> https://httpd.apache.org/docs/trunk/mod/mod_ssl.html#sslproxycacertificatepath
>> Il giorno 04/dic/2015, alle ore 17:24, mdoakes42 at verizon.net ha scritto:
>> Summary:  Using HTTPS Geoserver with Geonode.
>> I just finished installing geonode on a local test box and the app comes
>> up fine.   I have a remote GEOSERVER that is HTTPS enabled.   When I try to
>> upload layers I get an error in the server regarding
>> SSL_GET_SERVER_CERTIFICATE: certificate verify failed.
>> Can Geonode be configured so that I can communicate with an HTTPS enabled
>> Geoserver.    (In Geoserver we have to present a certificate (PKI) in order
>> to login).   On the geoserver side we basically have this installed
>> http://docs.geoserver.org/latest/en/user/security/tutorials/cert/
>> geonode-devel mailing list
>> geonode-devel at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/geonode-devel
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20151208/cc7658ab/attachment.html>
More information about the geonode-devel mailing list
