[GeoNode-devel] Using HTTPS Geoserver with Geonode.
Francesco Bartoli xbartolone at gmail.com
Sun Dec 13 06:45:42 PST 2015
Created the PR #2383
Il giorno 08/dic/2015, alle ore 05:41, Jeffrey Johnson <ortelius at gmail.com> ha scritto:
> Yes, this looks like the right place. A PR against the docs from someone would be very appreciated.
> On Mon, Dec 7, 2015 at 9:02 PM, Francesco Bartoli <xbartolone at gmail.com> wrote:
> Hi Jeff,
> agreed, it makes sense. Maybe here in these two places?
> https://github.com/GeoNode/geonode/blob/master/docs/tutorials/install_and_admin/geonode_install/setup_configure_httpd.txt
> https://github.com/GeoNode/geonode/blob/master/docs/tutorials/install_and_admin/setup_on_centos/install_base_httpd.txt
> Ciao
> Francesco
> Il giorno 07/dic/2015, alle ore 05:16, Jeffrey Johnson <ortelius at gmail.com> ha scritto:
>> Might be good to add something about this topic to the docs somewhere.
>> On Sat, Dec 5, 2015 at 10:44 PM, Francesco Bartoli <xbartolone at gmail.com> wrote:
>> Hi,
>> if your geonode instance is running within Apache then you have to instruct its httpd process to do not verify certificate of GeoServer in the proxy pass directive [1]. Otherwise if you have to verify it for security reasons then you should add its CA to the trusted store of CAs [2].
>> Hope this helps
>> Francesco
>> [1] https://httpd.apache.org/docs/trunk/mod/mod_ssl.html#sslproxyverify
>> [2] https://httpd.apache.org/docs/trunk/mod/mod_ssl.html#sslproxycacertificatepath
>> Il giorno 04/dic/2015, alle ore 17:24, mdoakes42 at verizon.net ha scritto:
>>> Summary:  Using HTTPS Geoserver with Geonode.
>>> I just finished installing geonode on a local test box and the app comes up fine.   I have a remote GEOSERVER that is HTTPS enabled.   When I try to upload layers I get an error in the server regarding SSL_GET_SERVER_CERTIFICATE: certificate verify failed.
>>> Can Geonode be configured so that I can communicate with an HTTPS enabled Geoserver.    (In Geoserver we have to present a certificate (PKI) in order to login).   On the geoserver side we basically have this installed
>>> http://docs.geoserver.org/latest/en/user/security/tutorials/cert/
>>> geonode-devel mailing list
>>> geonode-devel at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/geonode-devel
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20151213/2e68e31e/attachment.html>
More information about the geonode-devel mailing list
