[GeoNode-devel] Modify Base Maps
Paolo Corti pcorti at gmail.com
Mon Dec 14 12:47:22 PST 2015
If you updated the SITEURL variable, you will need to run updatelayers
on all of the existing layers to make them aware of this. This
action will take care of updating the thumbnail_url field.
regards
p
On Mon, Dec 14, 2015 at 3:13 PM,  <mdoakes42 at verizon.net> wrote:
> Hi Paolo,
> When I look in firebug for the URL for my thumb.  It shows
> https://localhost/uploaded/thumbs/........
> This URL should not be localhost..  It should be my server which is on a
> different machine then my client.
> I have my SITEURL set to be my server name (not localhost).
> Is there another setting sometwhere for the THumb Server?
> Thanks
> On 12/14/15, Paolo Corti<pcorti at gmail.com> wrote:
> Hi
> you can change your base maps, and using your internal ones, altering
> the MAP_BASELAYERS variable in your settings
> (http://docs.geonode.org/en/master/reference/developers/settings.html)
> Regarding the thumbnails not being generated, this could be a
> permission issue. You will need to give write permissions to your web
> server on the directory where thumbnails are being generated.
> regards
> p
> On Mon, Dec 14, 2015 at 12:16 PM, <mdoakes42 at verizon.net> wrote:
>> Hello
>> We are working in a closed environment without access to the outside
>> internet. Are there things that will not work out of the box that you
>> could help me identify.
>> Working with this for a short period I have experienced a couple issues so
>> far.
>> 1.) None of the basemaps will show (pink tiles....obviously cannot
>> connect).
>> -- My office maintains our own copy of basemaps which I'd like to
>> utilize. Are there configurations I can use to get rid of the default
>> basemaps (Bing Ariel, MapQuest, etc.... and to add my own basemaps. I
>> searched the source code and the only thing I see is that it looks like in
>> the GeoExplorer.js file there is some mention of these Basemaps...But not
>> sure if I can/should edit this directly or whether there is an easier way
>> to
>> add/remove basemaps selections.
>> 2.) My thumbnails are not generating.
>> Is there a way to check why this might not be working
>> Anything else anyone can make me aware of when working in a closed
>> environment with only access to the internal network. I'm sure I'll run
>> into some "social" network type things/links, etc... Just mainly
>> interested
>> in big things that might give me issues and any solutions you might have
>> to
>> correct these.
>> Thanks,
>> geonode-devel mailing list
>> geonode-devel at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/geonode-devel
> Paolo Corti
> Geospatial software developer
> web: http://www.paolocorti.net
> twitter: @capooti
> skype: capooti
Paolo Corti
twitter: @capooti
skype: capooti
More information about the geonode-devel mailing list
