[GeoNode-devel] Geonode/Geoserver "edit-check" error
Jeffrey Johnson ortelius at gmail.com
Tue Dec 15 07:20:01 PST 2015
The plugin for 2.7.4 is here.
http://build.geonode.org/geoserver/latest/
On Tue, Dec 15, 2015 at 7:17 AM,  <mdoakes42 at verizon.net> wrote:
> I have geoserver installed on a separate server from my geonode application.
> I've updated my local_settings.py appropriately and I can import a shape
> file and create layers with no problems.
> However, when I try and create a map and bring in some layers that were
> already in my database I get errors about 404 not Found.    There is a
> "POST" that is looking for gs/<layer>/edit-check but it is not found.
> The URL is pointing to my local GEONODE server and NOT my Geoserver server.
> Do you know why it cannot find this file?   (Is it because my Geoserver is
> remote?   Is there anything I can do to correct this?)
> A similar question.
> Is there anything else I need to do with having a remote geoserver?   I read
> somewhere about a "genode" extension?  Does this need to be put on the
> geoserver server?
> If so, Where can I get this?
> I installed the geoserver-printing module already and will look into
> installing mapfish but wondering if there is anythign else?
> Thanks
> geonode-devel mailing list
> geonode-devel at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geonode-devel
More information about the geonode-devel mailing list
