[GeoNode-devel] GeoGig plugin status?
Alessio Fabiani alessio.fabiani at geo-solutions.it
Tue Dec 22 05:21:33 PST 2015
Well as an instance now we should switch GeoNode dependency to GeoServer
2.8.x on master, but this is not possible until we fix the GeoGig
dependncies and build.
The best solution would be to, at least, have the GeoGig plugin as an
official GeoServer community plugin.
http://goo.gl/NWWaa2 for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via Poggio alle Viti 1187
55054  Massarosa (LU)
Italy
phone: +39 0584 962313
fax:     +39 0584 1660272
mob:   +39  331 6233686
http://www.geo-solutions.it
*AVVERTENZE AI SENSI DEL D.Lgs. 196/2003*
nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
loro utilizzo è consentito esclusivamente al destinatario del messaggio,
per le finalità indicate nel messaggio stesso. Qualora riceviate questo
messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
darcene notizia via e-mail e di procedere alla distruzione del messaggio
stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
utilizzarlo per finalità diverse, costituisce comportamento contrario ai
information in this message that has been received in error. The sender
does not give any warranty or accept liability as the content, accuracy or
completeness of sent messages and accepts no responsibility  for changes
On Tue, Dec 22, 2015 at 2:14 PM, Tyler Garner <garnertb at prominentedge.com>
wrote:
> Alessio,
> I use the GeoGIG Geoserver plugin on two projects that I currently work
> on.  We typically build the GeoGIG dependencies as snapshots, test them and
> then distribute them in a war instead of relying on official releases from
> the GeoGIG community.
> Happy to entertain any ideas you have, but so far I don't think we've been
> inconvenienced enough to justify forking GeoGIG and doing our own releases.
> -Tyler
> On Tue, Dec 22, 2015 at 4:57 AM, Alessio Fabiani <
> alessio.fabiani at geo-solutions.it> wrote:
>> Dear all,
>> currently the GeoGig plugin and stuff is not part of the official
>> GeoServer distribution ans also the project (as far as I know) is owned and
>> maintained by Boundlessgeo.
>> Now, the thing is: if things remain like this the GeoNode releasing and
>> branching will be always somehow constrained by bothering someone at
>> Baoundless to do another branch/release of GeoGig for GeoNode. Moreover it
>> would be better, IMHO, to avoid such kind of dependencies on an opendource
>> project like GeoNode.
>> My question is, is there someone on the community using the GeoGig plugin
>> actively? What is exactly the history and background of such plugin? Any
>> idea/requirement on how to proceed with this and solve the issue?
>> Thanks all,
>> Alessio Fabiani.
>> GeoServer Professional Services from the experts! Visit
>> @alfa7691
>> GeoSolutions S.A.S.
>> Italy
>> http://twitter.com/geosolutions_it
>> Le informazioni contenute in questo messaggio di posta elettronica e/o
>> principi dettati dal D.Lgs. 196/2003.
>> The information in this message and/or attachments, is intended solely
>> for the attention and use of the named addressee(s) and may be confidential
>> or proprietary in nature or covered by the provisions of privacy act
>> (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
>> Code).Any use not in accord with its purpose, any disclosure, reproduction,
>> copying, distribution, or either dissemination, either whole or partial, is
>> strictly forbidden except previous formal approval of the named
>> addressee(s). If you are not the intended recipient, please contact
>> immediately the sender by telephone, fax or e-mail and delete the
>> made after they were sent or for other risks which arise as a result of
>> e-mail transmission, viruses, etc.
>> geonode-devel mailing list
>> geonode-devel at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/geonode-devel
> *Tyler Garner*
> Co-Founder | Prominent Edge
> Office: 703-743-5434
> Mobile: 434-841-3803
> prominentedge.com
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20151222/405dae8e/attachment-0001.html>
More information about the geonode-devel mailing list
