[GeoNode-devel] GeoServer 2.7.x integration
Jeffrey Johnson ortelius at gmail.com
Mon Jul 6 08:18:50 PDT 2015
Alessio, You should be able to just modify this job now.
http://52.5.141.226/job/geoserver-geonode-dev/ ... the old build
server seems to be completely broken, so I cant look at the setup
there, but it should be a straightforward mvn jenkins job. Let us know
if you run into any trouble.
Simone and Ariel, can you guys help get the geoserver and
geonode-geoserver launchpad packages working with this new version as
well. We should try to get to a snapshots package that includes this
2.7 geoserver ASAP so we can do some testing in the next weeks before
releasing.
On Mon, Jul 6, 2015 at 8:14 AM, Alessio Fabiani
<alessio.fabiani at geo-solutions.it> wrote:
> Yes please, I never did it.
> I'll check the server though and take a look at the other jobs.
> Thanks,
> Alessio.
> P.S.: I updated the pom in order to automatically build the WAR into the
> target folder also, but if it is not needed we can remove it.
> GeoServer Professional Services from the experts! Visit
> http://goo.gl/NWWaa2 for more information.
> Ing. Alessio Fabiani
> @alfa7691
> Founder/Technical Lead
> GeoSolutions S.A.S.
> Via Poggio alle Viti 1187
> 55054  Massarosa (LU)
> Italy
> phone: +39 0584 962313
> fax:     +39 0584 1660272
> mob:   +39  331 6233686
> http://www.geo-solutions.it
> http://twitter.com/geosolutions_it
> AVVERTENZE AI SENSI DEL D.Lgs. 196/2003
> Le informazioni contenute in questo messaggio di posta elettronica e/o nel/i
> file/s allegato/i sono da considerarsi strettamente riservate. Il loro
> utilizzo è consentito esclusivamente al destinatario del messaggio, per le
> finalità indicate nel messaggio stesso. Qualora riceviate questo messaggio
> senza esserne il destinatario, Vi preghiamo cortesemente di darcene notizia
> via e-mail e di procedere alla distruzione del messaggio stesso,
> cancellandolo dal Vostro sistema. Conservare il messaggio stesso, divulgarlo
> anche in parte, distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per
> finalità diverse, costituisce comportamento contrario ai principi dettati
> dal D.Lgs. 196/2003.
> The information in this message and/or attachments, is intended solely for
> the attention and use of the named addressee(s) and may be confidential or
> proprietary in nature or covered by the provisions of privacy act
> (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
> Code).Any use not in accord with its purpose, any disclosure, reproduction,
> copying, distribution, or either dissemination, either whole or partial, is
> strictly forbidden except previous formal approval of the named
> addressee(s). If you are not the intended recipient, please contact
> immediately the sender by telephone, fax or e-mail and delete the
> information in this message that has been received in error. The sender does
> not give any warranty or accept liability as the content, accuracy or
> completeness of sent messages and accepts no responsibility  for changes
> made after they were sent or for other risks which arise as a result of
> e-mail transmission, viruses, etc.
> On Mon, Jul 6, 2015 at 5:11 PM, Jeffrey Johnson <ortelius at gmail.com> wrote:
>> Alessio,
>> Thanks for this!
>> Can I get you setup on the jenkins server to setup the job there to
>> build this and produce the war? I haven't done any work on configuring
>> that job since migrating off of the older build server. I've added
>> your GH username as an admin in this jenkins. You may need ssh access
>> in order to put the artifact in the right place on the filesystem so
>> we can update the packages and pavement script.
>> http://52.5.141.226/ (old one is here http://build.geonode.org:8088/,
>> still need to migrate the DNS)
>> Jeff
>> On Mon, Jul 6, 2015 at 8:04 AM, Alessio Fabiani
>> > Dear all,
>> > I had the chance to work on the integration of GeoServer 2.7.x with
>> > GeoNode
>> > master. Currently I updated the geoserver-geonode-ext code in order to
>> > build
>> > automatically the GeoServer WAR with the updated GS DATA DIR and the
>> > integrated secutiry module.
>> > All the test-cases pass and also I tested with a running version of
>> > GeoNode.
>> > I guess there could be some issues with the GeoTIFF uploading when using
>> > the
>> > Importer, but I'm still verifying.
>> > Here is the integration of GeoServer 2.7.x with GeoNode master.
>> > https://github.com/geosolutions-it/geoserver-geonode-ext/tree/2.7.x
>> > Have you the chance to test it and report any issue?
>> > Regards,
>> > Alessio.
>> > @alfa7691
>> > GeoSolutions S.A.S.
>> > Italy
>> > nel/i
>> > le
>> > messaggio
>> > notizia
>> > divulgarlo
>> > per
>> > dettati
>> > for
>> > or
>> > reproduction,
>> > is
>> > does
>> > _______________________________________________
>> > geonode-devel mailing list
>> > geonode-devel at lists.osgeo.org
>> > http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-devel
More information about the geonode-devel mailing list
