[GeoNode-devel] new geoserver build server
Simone Dalmasso simone.dalmasso at gmail.com
Tue Jul 7 23:17:16 PDT 2015
Thanks Jeff, all jobs fixed.
2015-07-08 1:55 GMT+02:00 Jeffrey Johnson <ortelius at gmail.com>:
> The DNS has propagated. demo.geonode.org and build.geonode.org both
> answer. I fixed the callback url and some of you should be able to
> login to jenkins now with your github account.
> Simone, lets fix up the demo job tomorrow and make sure its all running.
> On Tue, Jul 7, 2015 at 2:59 PM, Jeffrey Johnson <ortelius at gmail.com>
> wrote:
> > I just migrated the DNS, amazon weirdly recycled the elastic IP
> > address (or more likely my mistake), so for me demo.geonode.org is
> > pointing to the build server for now.
> > They should resolve this way shortly.
> > build 52.7.139.177
> > demo 54.173.247.36
> > On Tue, Jul 7, 2015 at 8:45 AM, Ariel Nunez <ingenieroariel at gmail.com>
> wrote:
> >> Ciao Simone,
> >> In the past:
> >>  - When we had trouble reporting bugs upstream geoserver it was best to
> be
> >> able to point at a stable version.
> >>  - If we wanted to switch the pom.xml to a point release, there were a
> lot
> >> of missing artifacts making snapshots the only solution (to be able to
> >> release against point releases we had to bug Justin to add missing jars
> to
> >> the maven repo),
> >>  - If people wanted to add other GeoServer plugins they could get them
> from
> >> GeoServer's build service.
> >> However, I agree with your suggestion to move master to 2.7-SNAPSHOT
> and can
> >> deal with the above once we release final.
> >> -a
> >> On Tue, Jul 7, 2015 at 10:26 AM, Alessio Fabiani
> >> <alessio.fabiani at geo-solutions.it> wrote:
> >>> Ariel,
> >>> just pushed in the merge of the conflicts.
> >>> -A.
> >>> GeoServer Professional Services from the experts! Visit
> >>> http://goo.gl/NWWaa2 for more information.
> >>> Ing. Alessio Fabiani
> >>> @alfa7691
> >>> Founder/Technical Lead
> >>> GeoSolutions S.A.S.
> >>> Via Poggio alle Viti 1187
> >>> 55054  Massarosa (LU)
> >>> Italy
> >>> phone: +39 0584 962313
> >>> fax:     +39 0584 1660272
> >>> mob:   +39 331 6233686
> >>> http://www.geo-solutions.it
> >>> http://twitter.com/geosolutions_it
> >>> AVVERTENZE AI SENSI DEL D.Lgs. 196/2003
> >>> Le informazioni contenute in questo messaggio di posta elettronica e/o
> >>> nel/i file/s allegato/i sono da considerarsi strettamente riservate.
> Il loro
> >>> utilizzo è consentito esclusivamente al destinatario del messaggio,
> per le
> >>> finalità indicate nel messaggio stesso. Qualora riceviate questo
> messaggio
> >>> senza esserne il destinatario, Vi preghiamo cortesemente di darcene
> notizia
> >>> via e-mail e di procedere alla distruzione del messaggio stesso,
> >>> cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
> divulgarlo
> >>> anche in parte, distribuirlo ad altri soggetti, copiarlo, od
> utilizzarlo per
> >>> finalità diverse, costituisce comportamento contrario ai principi
> dettati
> >>> dal D.Lgs. 196/2003.
> >>> The information in this message and/or attachments, is intended solely
> for
> >>> the attention and use of the named addressee(s) and may be
> confidential or
> >>> proprietary in nature or covered by the provisions of privacy act
> >>> (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
> >>> Code).Any use not in accord with its purpose, any disclosure,
> reproduction,
> >>> copying, distribution, or either dissemination, either whole or
> partial, is
> >>> strictly forbidden except previous formal approval of the named
> >>> addressee(s). If you are not the intended recipient, please contact
> >>> immediately the sender by telephone, fax or e-mail and delete the
> >>> information in this message that has been received in error. The
> sender does
> >>> not give any warranty or accept liability as the content, accuracy or
> >>> completeness of sent messages and accepts no responsibility  for
> changes
> >>> made after they were sent or for other risks which arise as a result of
> >>> e-mail transmission, viruses, etc.
> >>> On Tue, Jul 7, 2015 at 5:24 PM, Simone Giannecchini
> >>> <simone.giannecchini at geo-solutions.it> wrote:
> >>>> Ciao Ariel,
> >>>> quick thoughts, are we user we _don't_ want GeoNode master to lean
> >>>> onto GeoServer 2.7.x?
> >>>> I agree we should not have GeoNode Master depend on an unstable
> >>>> GeoServer but 2.7.x is already hence it is getting fixes and small new
> >>>> features.
> >>>> Using nightlies would ensure that whenever a fix is needed in
> >>>> GeoServer to move with GeoNode we get it right away rather than having
> >>>> to wait 1 or 2 months and coming up with a workaround.
> >>>> I might want to move back to fixed version once we talk about stable
> >>>> GeoNode, although even at that point we might want to leverage on the
> >>>> nightly for the maintenance branch of GeoServer so that we get bugixes
> >>>> right away.
> >>>> I believe that a strong link between GeoNode and GS is key for the
> >>>> success of the first one (or both :) ).
> >>>> Looking forward to reading your (and the others' feedback).
> >>>> Regards,
> >>>> Simone Giannecchini
> >>>> PS
> >>>> Apologize for pushing this quickly but we have a project with a
> >>>> limited time window where we want to really push this through for
> >>>> longer term maintainability.
> >>>> We are more than happy to comply with what the community decides on
> this.
> >>>> Visit http://goo.gl/it488V for more information.
> >>>> Ing. Simone Giannecchini
> >>>> @simogeo
> >>>> Founder/Director
> >>>> GeoSolutions S.A.S.
> >>>> Italy
> >>>> mob:   +39 333 8128928
> >>>> Il loro utilizzo è consentito esclusivamente al destinatario del
> >>>> messaggio, per le finalità indicate nel messaggio stesso. Qualora
> >>>> riceviate questo messaggio senza esserne il destinatario, Vi preghiamo
> >>>> cortesemente di darcene notizia via e-mail e di procedere alla
> >>>> distruzione del messaggio stesso, cancellandolo dal Vostro sistema.
> >>>> Conservare il messaggio stesso, divulgarlo anche in parte,
> >>>> distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per finalità
> >>>> diverse, costituisce comportamento contrario ai principi dettati dal
> >>>> D.Lgs. 196/2003.
> >>>> for the attention and use of the named addressee(s) and may be
> >>>> confidential or proprietary in nature or covered by the provisions of
> >>>> privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New
> >>>> Data Protection Code).Any use not in accord with its purpose, any
> >>>> disclosure, reproduction, copying, distribution, or either
> >>>> dissemination, either whole or partial, is strictly forbidden except
> >>>> previous formal approval of the named addressee(s). If you are not the
> >>>> intended recipient, please contact immediately the sender by
> >>>> telephone, fax or e-mail and delete the information in this message
> >>>> that has been received in error. The sender does not give any warranty
> >>>> or accept liability as the content, accuracy or completeness of sent
> >>>> messages and accepts no responsibility  for changes made after they
> >>>> were sent or for other risks which arise as a result of e-mail
> >>>> On Tue, Jul 7, 2015 at 4:59 PM, Ariel Nunez <ingenieroariel at gmail.com
> >>>> wrote:
> >>>> > Alessio,
> >>>> > I see you pegging it to 2.7-SNAPSHOT, is it possible to peg it to an
> >>>> > specific geoserver version?
> >>>> > Also, I saw there were merging issues against master in that PR,
> could
> >>>> > you
> >>>> > help resolve those before we can pull?
> >>>> > -a
> >>>> > On Tue, Jul 7, 2015 at 9:37 AM, Alessio Fabiani
> >>>> >> Hi all,
> >>>> >> the pull request for merging the geonode-geoserver-ext
> improvements is
> >>>> >> here
> >>>> >> https://github.com/GeoNode/geoserver-geonode-ext/pull/37
> >>>> >> while we still having a known issue when using the GeoServer
> Importer
> >>>> >> mechanism for the upload of the GeoTIFFs which has been reported
> here
> >>>> >> https://github.com/GeoNode/geonode/issues/2216
> >>>> >> Regards,
> >>>> >> Alessio Fabiani.
> >>>> >> @alfa7691
> >>>> >> GeoSolutions S.A.S.
> >>>> >> Italy
> e/o
> riservate.
> >>>> >> Il loro
> >>>> >> per le
> >>>> >> messaggio
> >>>> >> notizia
> >>>> >> divulgarlo
> >>>> >> utilizzarlo per
> >>>> >> dettati
> solely
> >>>> >> for
> >>>> >> confidential or
> >>>> >> Protection
> >>>> >> reproduction,
> >>>> >> partial, is
> >>>> >> sender does
> or
> >>>> >> changes
> result
> >>>> >> of
> >>>> >> On Tue, Jul 7, 2015 at 4:28 PM, Jeffrey Johnson <
> >>>> >> wrote:
> >>>> >>> Nice to see this building again!
> http://52.5.141.226/job/geoserver-geonode-dev/org.opengeo$geonode-geoserver-ext/
> >>>> >>> On Tue, Jul 7, 2015 at 7:27 AM, Jeffrey Johnson <
> >>>> >>> wrote:
> >>>> >>> > +1
> >>>> >>> > Thanks Alessio!
> >>>> >>> > On Tue, Jul 7, 2015 at 7:26 AM, Ariel Nunez
> >>>> >>> > wrote:
> >>>> >>> >> +1
> >>>> >>> >> On Tue, Jul 7, 2015 at 9:19 AM, Paolo Pasquali
> >>>> >>> >> <paolo.pasquali at ithaca.polito.it> wrote:
> >>>> >>> >>> +1
> >>>> >>> >>> No complains.
> >>>> >>> >>> Thank you Alessio!
> >>>> >>> >>> On Tue, Jul 7, 2015 at 4:16 PM, Simone Dalmasso
> >>>> >>> >>> <simone.dalmasso at gmail.com> wrote:
> >>>> >>> >>>> Hi devs,
> >>>> >>> >>>> thanks to @afabiani we have a new geoserver build server and
> >>>> >>> >>>> also
> >>>> >>> >>>> bump
> >>>> >>> >>>> it's version to 2.7.
> >>>> >>> >>>> We would like to migrate the DNS to this new one then. If
> there
> >>>> >>> >>>> are
> >>>> >>> >>>> no
> >>>> >>> >>>> complains from the community we will proceed in the next
> days.
> >>>> >>> >>>> the new geoserver will be available at
> >>>> >>> >>>> http://build.geonode.org/geoserver/latest/geoserver.war as
> >>>> >>> >>>> before
> >>>> >>> >>>> Note that this will only affect new installations in dev mode
> >>>> >>> >>>> for
> >>>> >>> >>>> now,
> >>>> >>> >>>> not the installations made via apt-get.
> >>>> >>> >>>> The GeoNode dev team
> >>>> >>> >>>> _______________________________________________
> >>>> >>> >>>> geonode-devel mailing list
> >>>> >>> >>>> geonode-devel at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-devel
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20150708/9bddb526/attachment-0001.html>
More information about the geonode-devel mailing list
