[GeoNode-devel] geoserver-geonode-ext - geonode_authorize_layer.sql modification
Jeffrey Johnson ortelius at gmail.com
Tue Jul 14 07:49:00 PDT 2015
This seems reasonable to me, but havent tested it. Anyone have any concerns
or objections to merging it?
On Mon, Jul 13, 2015 at 11:13 AM, Daniel Berry <dberry at boundlessgeo.com>
wrote:
> I would like to propose the pull request be added to the geoserver-geonode-ext master.
> https://github.com/GeoNode/geoserver-geonode-ext/pull/41
> The geonode_authorize_layer.sql does not work correctly for group authentication.
> When creating a new group an entry is added to the "auth_group" table with the first row automatically created for the anonymous group
> auth_group
> id [PK] serial, name character varying(80)
> 1,anonymous
> The geonode_authorize_layer function creates the group_ids (integer[]) by querying the "groups_groupmember"."group_id" column.
> The issue is that the group_id column does not account for the anonymous group. So when GeoServer is running the prepared statement. The result is actually "groups_groupmember"."group_id" -1. A quick fix is just to add 1 to each value in the "group_ids", since the anonymous group will always be the first entry.
> I replaced the following in geonode_authorize_layer.sql
> SELECT INTO group_ids array_agg("groups_groupmember"."group_id" + 1)
>   FROM "groups_groupmember"
>   WHERE "groups_groupmember"."user_id" = "user".id;
> with the following:
> *Daniel Berry*
> Professional Services Engineer | Boundless
> 512-468-3946 (cell)
> @boundlessgeo
> geonode-devel mailing list
> geonode-devel at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-devel
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20150714/7a64250c/attachment.html>
More information about the geonode-devel mailing list
