[GeoNode-devel] automatic authentication/login from geonode to geoserver does not work
Paolo Pasquali paolo.pasquali at ithaca.polito.it
Thu Jul 16 06:10:44 PDT 2015
Thanks Simone, it works.
And sorry, I've just realized that this point it is included in the Custom
Installation Guide.
Best,
Paolo
Paolo Pasquali
ITHACA - Information Technology for Humanitarian Assistance, Cooperation
and Action
via Pier Carlo Boggio, 61
10138 Torino - Italy
Tel. +39 011 1975 1872
Fax +39 011 1975 1122
On Thu, Jul 16, 2015 at 3:04 PM, Simone Dalmasso <simone.dalmasso at gmail.com>
wrote:
> I did not test it in a custom environment, the solution should be to set
> the /var/lib/tomcat7/webapps/geoserver/data/security/auth/geonodeAuthProvider/config.xml
> to localhost or to where geonode is responding.
> I'll try asap
> 2015-07-16 13:11 GMT+02:00 Simone Dalmasso <simone.dalmasso at gmail.com>:
>> Forwarding to the osgeo mailing list. Remember to consider the opengeo
>> one as dismissed
>> ---------- Forwarded message ----------
>> From: Paolo Pasquali <paolo.pasquali at gmail.com>
>> Date: 2015-07-16 12:47 GMT+02:00
>> Subject: Re: automatic authentication/login from geonode to geoserver
>> does not work
>> To: geonode-dev at opengeo.org
>> Cc: chrisy.wolf at gmail.com
>> Hi Devs,
>> I'm facing this same problem but with the latest GeoNode 2.4 beta and
>> GeoServer 2.7.
>> I made a custom installation in a virtualenv with both GeoNode and
>> GeoServer responding on port 80.
>> So I'm getting this error:
>> Error connecting to the GeoNode server for authentication purposes
>> GeoNode communication failed, status report is: 404, Not Found,
>> http://localhost/layers/acls
>> I played with the settings but without success.
>> Thanks in advanced for your help.
>> Bye
>> Paolo
>> On Wednesday, January 7, 2015 at 11:14:34 AM UTC+1, chris... at gmail.com
>> wrote:
>>> Hello,
>>> maybe somebody can help me.
>>> i have following problem:
>>> Geoserver application can not find geonode application on same server to
>>> authentificate and automatic login to geoserver with same credentials. I
>>> must login on geoserver app again. Also layer on geonode will not display
>>> because automatic login to geoserver app does not work.
>>> geoserver.log say:
>>> 2015-01-07 10:32:06,039 WARN [geonode.security] - Error connecting to
>>> org.springframework.security.authentication.AuthenticationServiceException:
>>> Communication with GeoNode failed
>>>         at
>>> org.geonode.security.GeoNodeAuthenticationProvider.authenticate(GeoNodeAuthenticationProvider.java:61)
>>>         at
>>> org.geoserver.security.GeoServerAuthenticationProvider.authenticate(GeoServerAuthenticationProvider.java:57)
>>>         at
>>> org.springframework.security.authentication.ProviderManager.authenticate(ProviderManager.java:156)
>>>         at
>>> org.geonode.security.GeoNodeAnonymousProcessingFilter.doFilter(GeoNodeAnonymousProcessingFilter.java:63)
>>>         at
>>> org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:323)
>>>         at
>>> org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:68)
>>>         at
>>> org.springframework.security.web.authentication.www.BasicAuthenticationFilter.doFilter(BasicAuthenticationFilter.java:150)
>>>         at
>>> org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:72)
>>>         at
>>> org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:91)
>>>         at
>>> org.geoserver.security.filter.GeoServerBasicAuthenticationFilter.doFilter(GeoServerBasicAuthenticationFilter.java:82)
>>>         at
>>>         at
>>> org.geonode.security.GeoNodeCookieProcessingFilter.doFilter(GeoNodeCookieProcessingFilter.java:107)
>>>         at
>>>         at
>>>         at
>>> org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:87)
>>>         at
>>> org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1.doFilter(GeoServerSecurityContextPersistenceFilter.java:52)
>>>         at
>>>         at
>>>         at
>>>         at
>>> org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:173)
>>>         at
>>> org.geoserver.security.GeoServerSecurityFilterChainProxy.doFilter(GeoServerSecurityFilterChainProxy.java:134)
>>>         at
>>> org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:346)
>>>         at
>>> org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:259)
>>>         at
>>> org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:241)
>>>         at
>>> org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208)
>>>         at
>>> org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:75)
>>>         at
>>>         at
>>>         at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:42)
>>>         at
>>>         at
>>>         at
>>> org.geoserver.filters.SessionDebugFilter.doFilter(SessionDebugFilter.java:47)
>>>         at
>>>         at
>>>         at
>>> org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:220)
>>>         at
>>> org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:122)
>>>         at
>>> org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:501)
>>>         at
>>> org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:170)
>>>         at
>>> org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:98)
>>>         at
>>> org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:950)
>>>         at
>>> org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:116)
>>>         at
>>> org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:408)
>>>         at
>>> org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:1040)
>>>         at
>>> org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:607)
>>>         at
>>> org.apache.tomcat.util.net.JIoEndpoint$SocketProcessor.run(JIoEndpoint.java:315)
>>>         at
>>> java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145)
>>>         at
>>> java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615)
>>>         at java.lang.Thread.run(Thread.java:745)
>>> Caused by: java.io.IOException: GeoNode communication failed, status
>>> report is: 404, Not Found, http://localhost:8080/layers/acls
>>>         at org.geonode.security.HTTPClient.sendGET(HTTPClient.java:72)
>>>         at
>>> org.geonode.security.DefaultSecurityClient.authenticate(DefaultSecurityClient.java:152)
>>>         at
>>> org.geonode.security.DefaultSecurityClient.authenticateAnonymous(DefaultSecurityClient.java:135)
>>>         at
>>> org.geonode.security.GeoNodeAuthenticationProvider.authenticate(GeoNodeAuthenticationProvider.java:48)
>>>         ... 47 more
>>> i have checked
>>> /opt/geonode/geoserver/geoserver/data/security/auth/geonodeAuthProvider/config.xml
>>> and set baseUrl to http://localhost and also http://localhost:8080 but
>>> both does not work.
>>> Apache listen on Port 80
>>> tcp        0      0 0.0.0.0:80              0.0.0.0:*
>>> LISTEN      0          5099632     15956/apache2
>>> Apache geonode.conf:
>>> WSGIDaemonProcess geonode user=www-data threads=15 processes=2
>>> <VirtualHost *:80>
>>>     Servername localhost
>>>     ServerAdmin webmaster at localhost
>>>     ErrorLog /var/log/apache2/error.log
>>>     LogLevel warn
>>>     CustomLog /var/log/apache2/access.log combined
>>>     WSGIProcessGroup geonode
>>>     WSGIPassAuthorization On
>>>     WSGIScriptAlias / /var/www/geonode/wsgi/geonode.wsgi
>>>     <Directory "/var/www/geonode/">
>>>        Order allow,deny
>>>         Options Indexes FollowSymLinks
>>>         Allow from all
>>>         IndexOptions FancyIndexing
>>>     </Directory>
>>>     Alias /static/ /var/www/geonode/static/
>>>     Alias /uploaded/ /var/www/geonode/uploaded/
>>>     Alias /robots.txt /var/www/geonode/robots.txt
>>>     <Directory "/var/www/geonode/uploaded/documents/">
>>>        Order allow,deny
>>>        Deny from all
>>>     </Directory>
>>>     <Proxy *>
>>>       Order allow,deny
>>>       Allow from all
>>>     </Proxy>
>>>     ProxyPreserveHost On
>>>     ProxyPass /geoserver http://localhost:8080/geoserver
>>>     ProxyPassReverse /geoserver http://localhost:8080/geoserver
>>> </VirtualHost>
>>> My environment:
>>> Ubuntu 14.04.1 LTS
>>> Geoserver 2.5.1
>>> Geonode 2.4dev
>>> Do you need more informations?
>>> Thanks for help
>>> Best regards
>>> Christian
>>  To unsubscribe from this group and stop receiving emails from it, send
>> an email to geonode-dev+unsubscribe at opengeo.org.
>> Simone
> Simone
> geonode-devel mailing list
> geonode-devel at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-devel
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20150716/d118799b/attachment-0001.html>
More information about the geonode-devel mailing list
