[GeoNode-devel] Calling the cops on the party in geonode.contrib
Paolo Corti pcorti at gmail.com
Mon Jul 20 06:06:11 PDT 2015
Regarding the settings specific to a contrib application, I think they
should live in a settings.py file for the given application.
Therefore, if myapp contains the settings MYAPP_SETTING1,
MYAPPING_SETTING2, I believe they should be contained in the
myapp/settings.py file, and we should import this settings file from
the main settings file only in case myapp is enabled (maybe via a
MYAPP_ENABLED setting in the main settings file)
We should also teach sphinx to build the documentation for each
contrib application from the README app file.
cheers
p
On Thu, Jul 16, 2015 at 5:48 PM, Jeffrey Johnson <ortelius at gmail.com> wrote:
> Hi All,
> I just pushed a commit directly to master that broke the build.
> https://github.com/GeoNode/geonode/commit/4baca0a24b65b9a2c656c47fd54c8c2f1c794acb
> This puts the geonode.contrib apps in GEONODE_CONTRIB_APPS in
> settings.py and makes sure they are *always* disabled by default.
> The test failure is here
> https://travis-ci.org/GeoNode/geonode/builds/71270871#L1645
> And the root cause is here
> https://github.com/GeoNode/geonode/pull/2206/files#diff-33cf4fcb0f4b5b8bf97b2d580c7eaec1R81
> No need to point fingers as this PR went through the process we have
> setup and was merged. We do however need to have some more guidelines
> about how contrib modules should be handled.
> After a quick chat with Simone and Ariel, I propose the following:
> * New contrib modules should be initially proposed as a GNIP and
> brought up on the list before submitting a PR
> * Contrib modules should go into the GEONODE_CONTRIB_APPS block in
> settings and _never_ be enabled by default.
> * Contrib modules should have their own requirements.txt and not add
> things to setup.py
> * Contrib modules should be verified to not break the build when
> enabled/disabled before merging
> * There should be minimal docs about what it does and how to use it
> etc. A README in the module is sufficient, a page in docs/
> Anything else I missed? Im +1 to keep the party going and looking
> forward to seeing interesting things in this part of the codebase, but
> we cant get sloppy.
> Jeff
> geonode-devel mailing list
> geonode-devel at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-devel
Paolo Corti
Geospatial software developer
web: http://www.paolocorti.net
twitter: @capooti
skype: capooti
More information about the geonode-devel mailing list
