[GeoNode-devel] Working on GeoNode Layers update issues
Alessio Fabiani alessio.fabiani at geo-solutions.it
Wed Jul 22 03:39:22 PDT 2015
Dear all,
I was taking a look at several GeoNode issues regarding the Layers update,
in particular it seems like there are problems sometimes while trying to
update the styles which seem to be ralted to GWC cache syncronization.
In particular the issues I'm referring to are the following ones:
https://github.com/GeoNode/geonode/issues/2146
https://github.com/GeoNode/geonode/issues/1870
https://github.com/GeoNode/geonode/issues/1656
https://github.com/GeoNode/geonode/issues/1798
I was wandering if there are some updates on them after the update to
GeoServer 2.7.x and/or if someone is working on them and what is theyr
current status.
More in general my idea would be to implement Python methods in order to
interact with the GWC REST interface and then review the GeoNode workflow
in order to better handle the Layer creation/update with GWC too.
If you agree, I can extend the gsconfig project with several
objects/methods allowing us to interact with the integrated GWC in
GeoServer as a first step.
While implementing and testing this stuff I would like also to take the
occasion to:
1. Test and fix the GWC integration on GeoServer side if needed
2. Extend the GWC REST interfaces on GeoServer side if needed
What do you think/suggest? Any thought on that?
http://goo.gl/NWWaa2 for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via Poggio alle Viti 1187
55054  Massarosa (LU)
Italy
phone: +39 0584 962313
fax:     +39 0584 1660272
mob:   +39  331 6233686
http://www.geo-solutions.it
*AVVERTENZE AI SENSI DEL D.Lgs. 196/2003*
nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
loro utilizzo è consentito esclusivamente al destinatario del messaggio,
per le finalità indicate nel messaggio stesso. Qualora riceviate questo
messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
darcene notizia via e-mail e di procedere alla distruzione del messaggio
stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
utilizzarlo per finalità diverse, costituisce comportamento contrario ai
information in this message that has been received in error. The sender
does not give any warranty or accept liability as the content, accuracy or
completeness of sent messages and accepts no responsibility  for changes
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20150722/d36eb03e/attachment.html>
More information about the geonode-devel mailing list
