[GeoNode-devel] [Incubator] MOTION: Accept GeoNode into incubation
Andrea Aime andrea.aime at geo-solutions.it
Thu Jul 23 11:04:30 PDT 2015
On Thu, Jul 23, 2015 at 7:58 PM, Jeffrey Johnson <ortelius at gmail.com> wrote:
> On Thu, Jul 23, 2015 at 9:51 AM, Jody Garnett <jody.garnett at gmail.com>
> wrote:
> > +1 (and thanks for volunteering David)
> > Small correction of the application. GeoServer and PostGIS are not OGC
> > certified at the present time.
> Curious how GeoServer could not be certified as its the reference
> implementation of several OGC standards. In any case, GeoNode is based
> on these 2 + pycsw.
OGC demands that one passes the certification once per year, we do run the
tests each night against our own servers, but the ones we use in the
nightlies are outdated,
and we haven't run the official test in a while (e..g, years).
Also, a reference implementation requires a sample server to be up and
running
all the time, another thing we don't have.
I've been using all my spare time in the last weeks to amend the first, and
have
GeoServer nightly builds run against a more recent version of the tests,
once
we are able to, we can run the official certification tests.
OGC might also looking at hosting GeoServer for the reference implementation
demo server.
So, eventually, if people help, these things will be fixed.
Cheers
Andrea
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions S.A.S.
Via Poggio alle Viti 1187
55054  Massarosa (LU)
Italy
phone: +39 0584 962313
fax: +39 0584 1660272
mob: +39  339 8844549
http://www.geo-solutions.it
*AVVERTENZE AI SENSI DEL D.Lgs. 196/2003*
nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
loro utilizzo è consentito esclusivamente al destinatario del messaggio,
per le finalità indicate nel messaggio stesso. Qualora riceviate questo
messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
darcene notizia via e-mail e di procedere alla distruzione del messaggio
stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
utilizzarlo per finalità diverse, costituisce comportamento contrario ai
information in this message that has been received in error. The sender
does not give any warranty or accept liability as the content, accuracy or
completeness of sent messages and accepts no responsibility  for changes
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20150723/d4eaf88a/attachment.html>
More information about the geonode-devel mailing list
