[GeoNode-devel] Broken geoserver-geonode-build
Daniel Berry dberry at boundlessgeo.com
Fri Jul 31 10:18:41 PDT 2015
Hi All,
The issue is with the gs-jdbcconfig extension. The repo.boundlegeo.com does
not have a SNAPSHOT version.
http://repo.boundlessgeo.com/main/org/geoserver/community/gs-jdbcconfig/
So a question to the community... Do I set the pom.xml to a set version,
research about creating a SNAPSHOT version or just allow users to
individually add the extension which they can download at
http://ares.opengeo.org/geoserver/2.7.x/.
... for now I am going to comment out the gs-jdbcconfig entry and do a pull
request.
Hopefully we can all come to a consensus on a way forward with the
Also I would like to apologize for not noticing that the SNAPSHOT version
did not exist.
Why do these things always seem to occur on a Friday...
On a different note, I also noticed that Jenkins was unable to connect to
any codehaus endpoints. Specifically the following:
  <pluginRepositories>
    <pluginRepository>
      <id>codehaus-snapshot-plugins</id>
      <name>codehaus-shapshot-plugins</name>
      <url>http://snapshots.repository.codehaus.org/</url>
      <snapshots>
        <enabled>true</enabled>
      </snapshots>
      <releases>
        <enabled>false</enabled>
       </releases>
    </pluginRepository>
  </pluginRepositories>
repo.boundlessgeo.org hosts the snapshots now, not codehaus, so we
could remove this.
Sincerely,
Dan
On Fri, Jul 31, 2015 at 10:37 AM, Jeffrey Johnson <ortelius at gmail.com>
wrote:
> Hi All,
> Looks like the jdbc-config addition has broken the builds in jenkins.
> http://build.geonode.org/job/geoserver-geonode-dev/lastBuild/console
> Daniel, Can you guys take a look at see whats up?
> Jeff
> geonode-devel mailing list
> geonode-devel at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-devel
*Daniel Berry*
Professional Services Engineer | Boundless
512-468-3946 (cell)
@boundlessgeo
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20150731/fc627f97/attachment.html>
More information about the geonode-devel mailing list
