[GeoNode-devel] Broken geoserver-geonode-build
Daniel Berry dberry at boundlessgeo.com
Fri Jul 31 10:28:04 PDT 2015
Can some one merge my pull request?
https://github.com/GeoNode/geoserver-geonode-ext/pull/43
Dan
On Fri, Jul 31, 2015 at 12:13 PM, Simone Giannecchini <
simone.giannecchini at geo-solutions.it> wrote:
> Dear All,
> JDBC Config is not used by default in GS at this stage, it is a
> community extension.
> We used in some set ups and I am pretty sure Boundless does use it as
> well but the point is that it is not in widespread use yet.
> Isn't it a bit risky to move it to default use in GeoNode, if that's
> what's been done here?
> Aside, the build is failing because community extensions are not
> deployed by the GeoServer nightly build (we only deploy releases).
> I believe that if this is the direction we want to take (mind you, I
> am not against it, I am just questioning a bit the lack of discussion
> :) ) we should first proposed to make this a first class extension in
> GeoServer land
> so we have 100% guarantee that this extension will be maintained over time.
> Looking forward to reading your feedback.
> Regards,
> Simone Giannecchini
> GeoServer Professional Services from the experts!
> Visit http://goo.gl/it488V for more information.
> Ing. Simone Giannecchini
> @simogeo
> Founder/Director
> GeoSolutions S.A.S.
> Via Poggio alle Viti 1187
> 55054  Massarosa (LU)
> Italy
> phone: +39 0584 962313
> fax:     +39 0584 1660272
> mob:   +39 333 8128928
> http://www.geo-solutions.it
> http://twitter.com/geosolutions_it
> AVVERTENZE AI SENSI DEL D.Lgs. 196/2003
> Le informazioni contenute in questo messaggio di posta elettronica e/o
> nel/i file/s allegato/i sono da considerarsi strettamente riservate.
> Il loro utilizzo è consentito esclusivamente al destinatario del
> messaggio, per le finalità indicate nel messaggio stesso. Qualora
> riceviate questo messaggio senza esserne il destinatario, Vi preghiamo
> cortesemente di darcene notizia via e-mail e di procedere alla
> distruzione del messaggio stesso, cancellandolo dal Vostro sistema.
> Conservare il messaggio stesso, divulgarlo anche in parte,
> distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per finalità
> diverse, costituisce comportamento contrario ai principi dettati dal
> D.Lgs. 196/2003.
> The information in this message and/or attachments, is intended solely
> for the attention and use of the named addressee(s) and may be
> confidential or proprietary in nature or covered by the provisions of
> privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New
> Data Protection Code).Any use not in accord with its purpose, any
> disclosure, reproduction, copying, distribution, or either
> dissemination, either whole or partial, is strictly forbidden except
> previous formal approval of the named addressee(s). If you are not the
> intended recipient, please contact immediately the sender by
> telephone, fax or e-mail and delete the information in this message
> that has been received in error. The sender does not give any warranty
> or accept liability as the content, accuracy or completeness of sent
> messages and accepts no responsibility  for changes made after they
> were sent or for other risks which arise as a result of e-mail
> transmission, viruses, etc.
> On Fri, Jul 31, 2015 at 5:44 PM, Daniel Berry <dberry at boundlessgeo.com>
> wrote:
> > Sure
> > On Jul 31, 2015 10:37 AM, "Jeffrey Johnson" <ortelius at gmail.com> wrote:
> >> Hi All,
> >> Looks like the jdbc-config addition has broken the builds in jenkins.
> >> http://build.geonode.org/job/geoserver-geonode-dev/lastBuild/console
> >> Daniel, Can you guys take a look at see whats up?
> >> Jeff
> >> _______________________________________________
> >> geonode-devel mailing list
> >> geonode-devel at lists.osgeo.org
> >> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-devel
*Daniel Berry*
Professional Services Engineer | Boundless
512-468-3946 (cell)
@boundlessgeo
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20150731/a20eeeae/attachment-0001.html>
More information about the geonode-devel mailing list
