[GeoNode-devel] Which GeoServer version we should use (i.e. nightlies VS releases)
Simone Giannecchini simone.giannecchini at geo-solutions.it
Fri Jul 31 10:55:56 PDT 2015
Dear All,
recently I have been discussing with other devs about which GS version
we should depend onto in GeoNode.
As you might know GeoServer has, at all times, 3 active branches:
- Master (2.8.x at this stage) which is open for development and is
considered unstable
- Stable (2.7.x now) which get minor developments + bug fixes
- Maintenance (2.6.x now) which gets only bug fixes
GS has a time-boxed release model so we more or less know when a
release for a certain branch will be made.
Generally speaking (at least IMHO) for a project like GN it is good to
depend on the stable branch. Master would be dangerous, Maintenance
could be moving too slow (but still an option).
So yeah, that's fine we are already doing that. The point is what to
do when we cut a GN release? Do we use a GS nightly ( they are all
marked clearly and then we can track it easily)? Do we only use
releases?
The obvious answer is to use releases from the stable branch and make
everybody happy. There is one problem though unless we align with the
GS releases we might have problem with doing GS bugfixes before a GN
release.
Let's talk about present times. Right now we are depending on 2.7.x
nightly, so if there's something bugging us in GS we fix it and the
day after we get the fix in GN. If on September 1st we want to release
GN 2.4 we won't have a GS release to use because 2.7.3 will be out in
October, hence we either wait or we ask the GeoServer community to
make an intermediate release (e.g. 2.7.2.1).
My proposal is as follows:
- try to track geoserver stable nightly in GN development
- tentatively align GN release to GS releases (they are done pretty
often anyway)
- if we want to do a GN release and we can't wait for a GS one, we ask
the GS community to cut an intermediate release
Feedback?
PS
I already started a similar discussion on the GS mailing asking for
opinions on this approach :)
Regards,
Simone Giannecchini
GeoServer Professional Services from the experts!
Visit http://goo.gl/it488V for more information.
Ing. Simone Giannecchini
@simogeo
Founder/Director
GeoSolutions S.A.S.
Via Poggio alle Viti 1187
55054  Massarosa (LU)
Italy
phone: +39 0584 962313
fax:     +39 0584 1660272
mob:   +39  333 8128928
http://www.geo-solutions.it
nel/i file/s allegato/i sono da considerarsi strettamente riservate.
Il loro utilizzo è consentito esclusivamente al destinatario del
messaggio, per le finalità indicate nel messaggio stesso. Qualora
riceviate questo messaggio senza esserne il destinatario, Vi preghiamo
cortesemente di darcene notizia via e-mail e di procedere alla
distruzione del messaggio stesso, cancellandolo dal Vostro sistema.
Conservare il messaggio stesso, divulgarlo anche in parte,
distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per finalità
diverse, costituisce comportamento contrario ai principi dettati dal
D.Lgs. 196/2003.
The information in this message and/or attachments, is intended solely
for the attention and use of the named addressee(s) and may be
confidential or proprietary in nature or covered by the provisions of
privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New
Data Protection Code).Any use not in accord with its purpose, any
disclosure, reproduction, copying, distribution, or either
dissemination, either whole or partial, is strictly forbidden except
previous formal approval of the named addressee(s). If you are not the
intended recipient, please contact immediately the sender by
telephone, fax or e-mail and delete the information in this message
that has been received in error. The sender does not give any warranty
or accept liability as the content, accuracy or completeness of sent
messages and accepts no responsibility  for changes made after they
were sent or for other risks which arise as a result of e-mail
transmission, viruses, etc.
More information about the geonode-devel mailing list
