[GeoNode-devel] Improvements in authentication [PR#30]
Emanuele Tajariol etj at geo-solutions.it
Mon Jun 15 01:53:09 PDT 2015
Hi Ariel,
I just created the pull request for the HTTPClient fix:
   https://github.com/GeoNode/geoserver-geonode-ext/pull/36
Please also check PR 35: it's about a race condition issue when running tests:
-  issue:   https://github.com/GeoNode/geoserver-geonode-ext/issues/34
-  PR:   https://github.com/GeoNode/geoserver-geonode-ext/pull/35
PR for #33 (AuthCache: make the timeout configurable) is still work in
progress.
   Thank you,
   Emanuele
Alle 15:59:21 di Thursday 11 June 2015, Ariel Nunez ha scritto:
> Thanks a lot for picking this up Emanuele. Looking forward to the PRs.
> On Thu, Jun 11, 2015 at 6:53 AM, Emanuele Tajariol <etj at geo-solutions.it>
> wrote:
> > Hi list,
> > a couple of months ago there has been a bit of discussion on this pull
> > request
> >    https://github.com/GeoNode/geoserver-geonode-ext/pull/30
> > which is still open.
> > I opened the issues related to the two different topics included in the
> > pullreq, so that they can be addressed separately:
> > - HTTPClient auth issue in multiple threads
> >   https://github.com/GeoNode/geoserver-geonode-ext/issues/32
> >   Which is the main issue related to a bug. In the comments the
> > participants
> >   agreed on the fix.
> > - AuthCache: make the timeout configurable
> >   https://github.com/GeoNode/geoserver-geonode-ext/issues/33
> >   Which is not related to a bug, but an improvement implemented and
> > discussed
> >   in the PR.
> >   There were different ideas about the cache timeout value to be used, so
> >   making this value configurable is the best way to go.
> > I will provide two different PRs related to the two topics.
> >    Cheers,
> >    Emanuele
GeoServer Professional Services from the experts!
Visit http://goo.gl/NWWaa2 for more information.
Ing. Emanuele Tajariol
Technical Lead
GeoSolutions S.A.S.
Via Poggio alle Viti 1187
55054  Massarosa (LU)
Italy
phone: +39 0584 962313
fax:    +39 0584 1660272
mob:   +39  380 2116282
http://www.geo-solutions.it
More information about the geonode-devel mailing list
