[GeoNode-devel] GeoNode 2.4 status
Francesco Bartoli xbartolone at gmail.com
Wed Jun 24 17:42:58 PDT 2015
Hi Paolo,
I have tried to upgrade geoserver-geonode-ext with alignment to the latest stable 2.7.1. After minor issues in dependencies the build fails at this point:
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.1:compile (default-compile) on project geonode-geoserver-ext: Compilation failure: Compilation failure:
[ERROR] /Users/geobart/Development/geoserver-geonode-ext/src/main/java/org/geonode/security/GeoNodeSecurityProvider.java:[18,33] cannot find symbol
[ERROR] symbol:   class GeoserverDataDirectory
[ERROR] location: package org.vfny.geoserver.global
[ERROR] /Users/geobart/Development/geoserver-geonode-ext/src/main/java/org/geonode/security/GeoNodeSecurityProvider.java:[85,44] cannot find symbol
[ERROR] symbol:   variable GeoserverDataDirectory
[ERROR] location: class org.geonode.security.GeoNodeSecurityProvider
[ERROR] -> [Help 1]
org.apache.maven.lifecycle.LifecycleExecutionException: Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:3.1:compile (default-compile) on project geonode-geoserver-ext: Compilation failure
	at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:212)
	at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:153)
	at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:145)
	at org.apache.maven.lifecycle.internal.LifecycleModuleBuilder.buildProject(LifecycleModuleBuilder.java:116)
	at org.apache.maven.lifecycle.internal.LifecycleModuleBuilder.buildProject(LifecycleModuleBuilder.java:80)
	at org.apache.maven.lifecycle.internal.builder.singlethreaded.SingleThreadedBuilder.build(SingleThreadedBuilder.java:51)
	at org.apache.maven.lifecycle.internal.LifecycleStarter.execute(LifecycleStarter.java:128)
	at org.apache.maven.DefaultMaven.doExecute(DefaultMaven.java:307)
	at org.apache.maven.DefaultMaven.doExecute(DefaultMaven.java:193)
	at org.apache.maven.DefaultMaven.execute(DefaultMaven.java:106)
	at org.apache.maven.cli.MavenCli.execute(MavenCli.java:862)
	at org.apache.maven.cli.MavenCli.doMain(MavenCli.java:286)
	at org.apache.maven.cli.MavenCli.main(MavenCli.java:197)
	at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
	at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
	at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
	at java.lang.reflect.Method.invoke(Method.java:606)
	at org.codehaus.plexus.classworlds.launcher.Launcher.launchEnhanced(Launcher.java:289)
	at org.codehaus.plexus.classworlds.launcher.Launcher.launch(Launcher.java:229)
	at org.codehaus.plexus.classworlds.launcher.Launcher.mainWithExitCode(Launcher.java:415)
	at org.codehaus.plexus.classworlds.launcher.Launcher.main(Launcher.java:356)
Caused by: org.apache.maven.plugin.compiler.CompilationFailureException: Compilation failure
	at org.apache.maven.plugin.compiler.AbstractCompilerMojo.execute(AbstractCompilerMojo.java:858)
	at org.apache.maven.plugin.compiler.CompilerMojo.execute(CompilerMojo.java:129)
	at org.apache.maven.plugin.DefaultBuildPluginManager.executeMojo(DefaultBuildPluginManager.java:134)
	at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:208)
	... 20 more
[ERROR]
[ERROR] Re-run Maven using the -X switch to enable full debug logging.
[ERROR]
[ERROR] For more information about the errors and possible solutions, please read the following articles:
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/MojoFailureException
Tomorrow I don’t have time to investigating more but if somebody can take a look then I can retry the build. Anyway attached there is the POM used to build
Cheers,
Francesco
Type: application/xml
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20150625/08a516e8/attachment.xml>
Il giorno 24/giu/2015, alle ore 15:47, Paolo Corti <pcorti at gmail.com> ha scritto:
> Hi Simone
>> There are also a couple of other things that can be addressed before the
>> release if they are fixed in time otherwise will go to 2.4.1:
>> - notifications rework
>> - better cache management and invalidation for thumbnails and tiles
>> - Geoserver upgrade to 2.7
> We should upgrade asap GeoServer as this recently discovered important
> security vulnerability has been fixed only for 2.6.4 and 2.7.2 (we
> should consider to repackage GeoServer for stable 2.0 imho):
> https://osgeo-org.atlassian.net/browse/GEOS-7032
> For the rest, migrations script [1] worked well for us (WFP), we are
> extensively testing it and will go in production with 2.4 by the end
> of the month.
> Another think I would love to see in 2.4 is the gxp classify tool,
> almost done by Matt I believe [2]
> cheers
> p
> [1] https://github.com/capooti/geonode/tree/migration_from20_to_24
> [2] https://github.com/boundlessgeo/gxp/pull/231/files#r31339623
> Paolo Corti
> Geospatial software developer
> web: http://www.paolocorti.net
> twitter: @capooti
> skype: capooti
> geonode-devel mailing list
> geonode-devel at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-devel
More information about the geonode-devel mailing list
