[GeoNode-devel] Geonode Installation :-Paver start error:
Jeffrey Johnson ortelius at gmail.com
Fri Jun 26 07:34:41 PDT 2015
We have a TEM with them (Andy et al) next week and can bring it up then.
On Fri, Jun 26, 2015 at 7:30 AM, Paolo Corti <pcorti at gmail.com> wrote:
> Regarding old list, the ones on google group are currently disabled,
> but the one hosted at boundless are still alive. Unluckily we did not
> get any feedback from them when doing the list migration, so maybe
> this is a new chance to ask them if they could do it.
> p
> On Fri, Jun 26, 2015 at 4:17 PM, Jeffrey Johnson <ortelius at gmail.com> wrote:
>> Forwarding to the new dev list, Not sure if we can get the old one
>> totally removed now?
>> Barun,
>> Can you check if you have the GeoServer that you installed from
>> packages running. Check http://localhost:8080/geoserver. You should
>> also have the geonode python running in apache on http://localhost/
>> ... if so then you need only use paver start_django to stop and start
>> the python in development mode on port 8000 and reuse the package
>> installed geoserver. You can use python manage.py updatelayers to add
>> the layers installed with geoserver to your local development
>> database.
>> Grab me on slack if you need help with these issues.
>> Jeff
>> On Fri, Jun 26, 2015 at 3:06 AM,  <paudel.barun4 at gmail.com> wrote:
>>> Hi everyone,
>>> I have freshly installed Ubuntu 14.04 LTS. I have tried to install Geonode
>>> and i have followed this doc for installation.
>>> http://geonode.readthedocs.org/en/latest/tutorials/devel/install_devmode/index.html#install-devmode
>>> After installing Virtual Wrapper and cloning geonode from
>>> https://github.com/geoNode/geonode.git.
>>> I have followed following Procedures.
>>> 1.barun at barun-H81M-S2PV:~$ source /home/barun/.venvs/geonode/bin/activate
>>> 2.(geonode)barun at barun-H81M-S2PV:/$  sudo  pip install -e geonode
>>> 3 (geonode)barun at barun-H81M-S2PV:/$ cd geonode
>>> 4.(geonode)barun at barun-H81M-S2PV:/geonode$  sudo paver setup
>>> _____________________________________________________________________________________________
>>> (Message at the bottom):
>>> GeoNode development environment successfully set up.If you have not set up
>>> an administrative account, please do so now. Use "paver start" to start up
>>> the server.
>>> But at this stage i get an error:
>>> 5. (geonode)barun at barun-H81M-S2PV:/geonode$ paver start
>>> ---> pavement.start
>>> ---> pavement.start_geoserver
>>> cd /geonode/geoserver/data
>>> java -version
>>> java version "1.7.0_79"
>>> OpenJDK Runtime Environment (IcedTea 2.5.5) (7u79-2.5.5-0ubuntu0.14.04.2)
>>> OpenJDK Server VM (build 24.79-b02, mixed mode)
>>> java -Xmx512m -XX:MaxPermSize=256m
>>> -DGEOSERVER_DATA_DIR=/geonode/geoserver/data
>>> -Dorg.eclipse.jetty.server.webapp.parentLoaderPriority=true -jar
>>> /geonode/downloaded/jetty-runner-8.1.8.v20121106.jar --log
>>> /geonode/geoserver/jetty.log /geonode/scripts/misc/jetty-runner.xml >
>>> /dev/null &
>>> cd /geonode
>>> Starting GeoServer on http://localhost:8080/geoserver/
>>> 2015-06-26 12:52:08.998:INFO:omjr.Runner:Runner
>>> 2015-06-26 12:52:08.999:WARN:omjr.Runner:No tx manager found
>>> 2015-06-26 12:52:09.081:INFO:oejs.Server:jetty-8.y.z-SNAPSHOT
>>> Null identity service, trying login service: null
>>> Finding identity service: null
>>> 2015-06-26 12:52:09.408:INFO:oejsh.ContextHandler:started
>>> o.e.j.w.WebAppContext{/geoserver,file:/geonode/geoserver/geoserver/},../geoserver
>>> 2015-06-26 12:52:09.410:INFO:oejsh.ContextHandler:started
>>> 2015-06-26 12:52:09.853:INFO:oejsh.ContextHandler:started
>>> log4j:WARN File option not set for appender [geoserverlogfile].
>>> log4j:WARN Are you using FileAppender instead of ConsoleAppender?
>>> log4j:ERROR setFile(null,true) call failed.
>>> java.io.FileNotFoundException:
>>> /geonode/geoserver/geoserver/data/logs/geoserver.log (Permission denied)
>>>         at java.io.FileOutputStream.open(Native Method)
>>>         at java.io.FileOutputStream.<init>(FileOutputStream.java:221)
>>>         at java.io.FileOutputStream.<init>(FileOutputStream.java:142)
>>>         at org.apache.log4j.FileAppender.setFile(FileAppender.java:289)
>>>         at
>>> org.apache.log4j.RollingFileAppender.setFile(RollingFileAppender.java:167)
>>>         at
>>> org.apache.log4j.FileAppender.activateOptions(FileAppender.java:163)
>>>         at
>>> org.apache.log4j.config.PropertySetter.activate(PropertySetter.java:256)
>>>         at
>>> org.apache.log4j.config.PropertySetter.setProperties(PropertySetter.java:13
>>> at
>>> org.apache.log4j.config.PropertySetter.setProperties(PropertySetter.java:96)
>>>         at
>>> org.apache.log4j.PropertyConfigurator.parseAppender(PropertyConfigurator.java:654)
>>>         at
>>> org.apache.log4j.PropertyConfigurator.parseCategory(PropertyConfigurator.java:612)
>>>         at
>>> org.apache.log4j.PropertyConfigurator.configureRootCategory(PropertyConfigurator.java:509)
>>>         at
>>> org.apache.log4j.PropertyConfigurator.doConfigure(PropertyConfigurator.java:415)
>>>         at
>>> org.apache.log4j.PropertyConfigurator.configure(PropertyConfigurator.java:349)
>>>         at
>>> org.geoserver.logging.LoggingUtils.configureGeoServerLogging(LoggingUtils.java:86)
>>>         at
>>> org.geoserver.logging.LoggingUtils.initLogging(LoggingUtils.java:181)
>>>         at
>>> org.geoserver.logging.LoggingStartupContextListener.contextInitialized(LoggingStartupContextListener.java:73)
>>>         at
>>> org.eclipse.jetty.server.handler.ContextHandler.callContextInitialized(ContextHandler.java:771)
>>>         at
>>> org.eclipse.jetty.servlet.ServletContextHandler.callContextInitialized(ServletContextHandler.java:424)
>>>         at
>>> org.eclipse.jetty.server.handler.ContextHandler.startContext(ContextHandler.java:763)
>>>         at
>>> org.eclipse.jetty.servlet.ServletContextHandler.startContext(ServletContextHandler.java:249)
>>>         at
>>> org.eclipse.jetty.webapp.WebAppContext.startContext(WebAppContext.java:1250)
>>>         at
>>> org.eclipse.jetty.server.handler.ContextHandler.doStart(ContextHandler.java:706)
>>>         at
>>> org.eclipse.jetty.webapp.WebAppContext.doStart(WebAppContext.java:492)
>>>         at
>>> org.eclipse.jetty.util.component.AbstractLifeCycle.start(AbstractLifeCycle.java:64)
>>>         at
>>> org.eclipse.jetty.server.handler.HandlerCollection.doStart(HandlerCollection.java:229)
>>>         at
>>> org.eclipse.jetty.server.handler.ContextHandlerCollection.doStart(ContextHandlerCollection.java:172)
>>> ______________________________________________________________________________________________
>>> (edited)
>>> To unsubscribe from this group and stop receiving emails from it, send an
>>> email to geonode-dev+unsubscribe at opengeo.org.
>> geonode-devel mailing list
>> geonode-devel at lists.osgeo.org
>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-devel
> Paolo Corti
> Geospatial software developer
> web: http://www.paolocorti.net
> twitter: @capooti
> skype: capooti
More information about the geonode-devel mailing list
