[GeoNode-devel] Geonode Installation :-Paver start error:
Ariel Nunez ingenieroariel at gmail.com
Fri Jun 26 21:37:12 PDT 2015
Copying the right developers list.
You just need to do:
sudo chown $user -R /geonode
And things should work.
Since you want to develop, it is best to stay away from packages, those are
usually good for people who want to set up a GeoNode but do not have a lot
of software development experience. Most developers here have their own
scripts (fabric, ansible, docker) to maintain geonode installations.
-a
On Fri, Jun 26, 2015 at 2:32 PM, Barun Paudel <paudel.barun4 at gmail.com>
wrote:
> Hi Ariel,
> Thanking you for your kind response.
> Geonode is in this file directory.
> (geonode)barun at barun-H81M-S2PV:/geonode$ pwd
> /geonode
> My appologies, i couldnt remember i used root or (barun at barun-H81M-S2PV:~$)
> to clone geonode?? :(
> I am doing this right now:
> 1.Open the terminal
> 2.Activated my virtual environment
> 3. I wanted to install geonode in my virtual environment.
>                   a. Earlier i tried : pip install -e geonode
> --use-mirrors
>                   b.cd geonode
>                   c.paver start
> (It loads http://localhost:8080/geoserver
>  but  in http://localhost:8080/
> It gives the error like this.
> No context on this server matched or handled this request.
> Contexts known to this server are:
>    /geoserver ---> o.e.j.w.WebAppContext{/geoserver,file:/geonode/geoserver/geoserver/},../geoserver
>    <http://localhost:8080/geoserver>
>  It means geonode hasn't installed properly right?
> So how can i delete existing geonode (location :/geonode) and then
> download it from snapshot or testing repository? Then get it installed to
> my virtual environment?
> or just change the permission of geonode  and see right what happens?
> I would be glad if you let me know how to change the owner of geonode to
> barun?
> sudo chmod $user /geonode? Is it correct command?
> Thanks in advance for your reply!
> Stay awesome!
> Barun
> Barun Paudel
> Mobile       +94(0)71 654 6939
> E-mail        *paudel.barun4 at gmail.com <paudel.barun4 at gmail.com>*
> Skype       barunpaudel
> http://about.me/BarunPaudel
> On Fri, Jun 26, 2015 at 7:27 PM, Ariel Nunez <ingenieroariel at gmail.com>
> wrote:
>> On Fri, Jun 26, 2015 at 5:06 AM, <paudel.barun4 at gmail.com> wrote:
>>> /geonode/geoserver/geoserver/data/logs/geoserver.log
>> Barun,
>> Are you setting up /geonode in the root? If so, did you use root to clone
>> it and then switched to your regular user? It seems to me like a permission
>> problem, the 'barun' user should be set as the owner of /geonode/
>> -a
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20150626/e25900c7/attachment.html>
More information about the geonode-devel mailing list
