[GeoNode-devel] flake8: problems detecting unused imports
Paolo Corti pcorti at gmail.com
Tue Mar 10 05:52:27 PDT 2015
for what is worth not even updating pep from 1.5.7 to 1.6.2 seems to fix things.
cheers
p
On Tue, Mar 10, 2015 at 1:49 PM, Simone Dalmasso
<simone.dalmasso at gmail.com> wrote:
> The strange thing is that we have specified the pep8 version in setup.py
> https://github.com/GeoNode/geonode/blob/master/setup.py#L146, I'm sure that
> the reason of the issue si the old version of pep8 but why is not installed
> with setup.py?
> 2015-03-10 12:36 GMT+01:00 Paolo Corti <pcorti at gmail.com>:
>> Hi devs
>> today I am experiencing a weird problem with the flake8 and its
>> dependencies that come installed with GeoNode in a virtualenv. This
>> flake8 seems not to be able to recognize unused imports.
>> How to replicate:
>> $ virtualenv --no-site-packages env
>> $ . env/bin/activate
>> $ pip install -e .
>> now if I run flake8 the unused imports are not detected.
>> This is what I have:
>> $ flake8 --version
>> 2.3.0 (pep8: 1.5.7) CPython 2.7.3 on Linux
>> Instead if I create a fresh virtualenv and I just install flake8 it
>> seems to work (note the output of flake8 --version, it is different
>> and seems containing references to pyflakes and mccabe):
>> $ virtualenv --no-site-packages env_flake8
>> $ . env_flake8/bin/activate
>> $ pip install flake8==2.3.0
>> $ flake8 --version
>> 2.3.0 (pep8: 1.6.2, pyflakes: 0.8.1, mccabe: 0.3) CPython 2.7.3 on Linux
>> $ flake8 geonode
>> geonode/geoserver/tests.py:10:1: F401 'Client' imported but unused
>> geonode/tests/smoke.py:22:1: F401 'Client' imported but unused
>> geonode/documents/tests.py:10:1: F401 'Client' imported but unused
>> geonode/people/tests.py:21:1: F401 'Client' imported but unused
>> geonode/tests/integration.py:32:1: F401 'Client' imported but unused
>> any idea of what can be causing the failure?
>> thanks
>> p
>> Paolo Corti
>> Geospatial software developer
>> web: http://www.paolocorti.net
>> twitter: @capooti
>> skype: capooti
>> geonode-devel mailing list
>> geonode-devel at lists.osgeo.org
>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-devel
> Simone
Paolo Corti
twitter: @capooti
skype: capooti
More information about the geonode-devel mailing list
