[GeoNode-devel] flake8: problems detecting unused imports
Paolo Corti pcorti at gmail.com
Tue Mar 10 06:15:27 PDT 2015
They are already in my virtualenv, installed by the geonode setup
process. I updated pep8 to 1.6.2 but no joy:
flake8==2.3.0
mccabe==0.3
pep8==1.6.2
pyflakes==0.8.1
Simone, can you replicate this in your development computer?
Try to recreate a virtualenv and see if it happens to you as well
p
On Tue, Mar 10, 2015 at 2:01 PM, Simone Dalmasso
<simone.dalmasso at gmail.com> wrote:
> Do you think that we should specify all the components? pyflakes and mccabe.
> 2015-03-10 13:52 GMT+01:00 Paolo Corti <pcorti at gmail.com>:
>> for what is worth not even updating pep from 1.5.7 to 1.6.2 seems to fix
>> things.
>> cheers
>> p
>> On Tue, Mar 10, 2015 at 1:49 PM, Simone Dalmasso
>> > The strange thing is that we have specified the pep8 version in setup.py
>> > https://github.com/GeoNode/geonode/blob/master/setup.py#L146, I'm sure
>> > that
>> > the reason of the issue si the old version of pep8 but why is not
>> > installed
>> > with setup.py?
>> > 2015-03-10 12:36 GMT+01:00 Paolo Corti <pcorti at gmail.com>:
>> >> Hi devs
>> >> today I am experiencing a weird problem with the flake8 and its
>> >> dependencies that come installed with GeoNode in a virtualenv. This
>> >> flake8 seems not to be able to recognize unused imports.
>> >> How to replicate:
>> >> $ virtualenv --no-site-packages env
>> >> $ . env/bin/activate
>> >> $ pip install -e .
>> >> now if I run flake8 the unused imports are not detected.
>> >> This is what I have:
>> >> $ flake8 --version
>> >> 2.3.0 (pep8: 1.5.7) CPython 2.7.3 on Linux
>> >> Instead if I create a fresh virtualenv and I just install flake8 it
>> >> seems to work (note the output of flake8 --version, it is different
>> >> and seems containing references to pyflakes and mccabe):
>> >> $ virtualenv --no-site-packages env_flake8
>> >> $ . env_flake8/bin/activate
>> >> $ pip install flake8==2.3.0
>> >> $ flake8 --version
>> >> 2.3.0 (pep8: 1.6.2, pyflakes: 0.8.1, mccabe: 0.3) CPython 2.7.3 on
>> >> Linux
>> >> $ flake8 geonode
>> >> geonode/geoserver/tests.py:10:1: F401 'Client' imported but unused
>> >> geonode/tests/smoke.py:22:1: F401 'Client' imported but unused
>> >> geonode/documents/tests.py:10:1: F401 'Client' imported but unused
>> >> geonode/people/tests.py:21:1: F401 'Client' imported but unused
>> >> geonode/tests/integration.py:32:1: F401 'Client' imported but unused
>> >> any idea of what can be causing the failure?
>> >> thanks
>> >> p
>> >> Paolo Corti
>> >> Geospatial software developer
>> >> web: http://www.paolocorti.net
>> >> twitter: @capooti
>> >> skype: capooti
>> >> _______________________________________________
>> >> geonode-devel mailing list
>> >> geonode-devel at lists.osgeo.org
>> >> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-devel
>> > Simone
>> Paolo Corti
>> twitter: @capooti
>> skype: capooti
> Simone
Paolo Corti
twitter: @capooti
skype: capooti
More information about the geonode-devel mailing list
