[GeoNode-devel] flake8: problems detecting unused imports
Paolo Corti pcorti at gmail.com
Tue Mar 10 06:38:48 PDT 2015
Then it looks like the only difference in my system is Python 2.7.3.
I am using pip version 6.0.8, you?
I cannot figure out what can break this, specially considering that
when creating a virtual environment with just flake8 then this works
correctly recognizing the unused imports. If I install in the same
virtual environment geonode then flake8 is broken.
thanks again
p
On Tue, Mar 10, 2015 at 2:27 PM, Simone Dalmasso
<simone.dalmasso at gmail.com> wrote:
> Paolo I cannot replicate this, I just created a new venv and installed
> geonode in it and I see the pep8 violations.
> here my versions 2.3.0 (pep8: 1.6.2, pyflakes: 0.8.1, mccabe: 0.3) CPython
> 2.7.6 on Linux
> 2015-03-10 14:15 GMT+01:00 Paolo Corti <pcorti at gmail.com>:
>> They are already in my virtualenv, installed by the geonode setup
>> process. I updated pep8 to 1.6.2 but no joy:
>> flake8==2.3.0
>> mccabe==0.3
>> pep8==1.6.2
>> pyflakes==0.8.1
>> Simone, can you replicate this in your development computer?
>> Try to recreate a virtualenv and see if it happens to you as well
>> p
>> On Tue, Mar 10, 2015 at 2:01 PM, Simone Dalmasso
>> > Do you think that we should specify all the components? pyflakes and
>> > mccabe.
>> > 2015-03-10 13:52 GMT+01:00 Paolo Corti <pcorti at gmail.com>:
>> >> for what is worth not even updating pep from 1.5.7 to 1.6.2 seems to
>> >> fix
>> >> things.
>> >> cheers
>> >> p
>> >> On Tue, Mar 10, 2015 at 1:49 PM, Simone Dalmasso
>> >> > The strange thing is that we have specified the pep8 version in
>> >> > setup.py
>> >> > https://github.com/GeoNode/geonode/blob/master/setup.py#L146, I'm
>> >> > sure
>> >> > that
>> >> > the reason of the issue si the old version of pep8 but why is not
>> >> > installed
>> >> > with setup.py?
>> >> > 2015-03-10 12:36 GMT+01:00 Paolo Corti <pcorti at gmail.com>:
>> >> >> Hi devs
>> >> >> today I am experiencing a weird problem with the flake8 and its
>> >> >> dependencies that come installed with GeoNode in a virtualenv. This
>> >> >> flake8 seems not to be able to recognize unused imports.
>> >> >> How to replicate:
>> >> >> $ virtualenv --no-site-packages env
>> >> >> $ . env/bin/activate
>> >> >> $ pip install -e .
>> >> >> now if I run flake8 the unused imports are not detected.
>> >> >> This is what I have:
>> >> >> $ flake8 --version
>> >> >> 2.3.0 (pep8: 1.5.7) CPython 2.7.3 on Linux
>> >> >> Instead if I create a fresh virtualenv and I just install flake8 it
>> >> >> seems to work (note the output of flake8 --version, it is different
>> >> >> and seems containing references to pyflakes and mccabe):
>> >> >> $ virtualenv --no-site-packages env_flake8
>> >> >> $ . env_flake8/bin/activate
>> >> >> $ pip install flake8==2.3.0
>> >> >> $ flake8 --version
>> >> >> 2.3.0 (pep8: 1.6.2, pyflakes: 0.8.1, mccabe: 0.3) CPython 2.7.3 on
>> >> >> Linux
>> >> >> $ flake8 geonode
>> >> >> geonode/geoserver/tests.py:10:1: F401 'Client' imported but unused
>> >> >> geonode/tests/smoke.py:22:1: F401 'Client' imported but unused
>> >> >> geonode/documents/tests.py:10:1: F401 'Client' imported but unused
>> >> >> geonode/people/tests.py:21:1: F401 'Client' imported but unused
>> >> >> geonode/tests/integration.py:32:1: F401 'Client' imported but unused
>> >> >> any idea of what can be causing the failure?
>> >> >> thanks
>> >> >> p
>> >> >> Paolo Corti
>> >> >> Geospatial software developer
>> >> >> web: http://www.paolocorti.net
>> >> >> twitter: @capooti
>> >> >> skype: capooti
>> >> >> _______________________________________________
>> >> >> geonode-devel mailing list
>> >> >> geonode-devel at lists.osgeo.org
>> >> >> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-devel
>> >> > Simone
>> >> Paolo Corti
>> >> twitter: @capooti
>> >> skype: capooti
>> > Simone
>> Paolo Corti
>> twitter: @capooti
>> skype: capooti
> Simone
Paolo Corti
twitter: @capooti
skype: capooti
More information about the geonode-devel mailing list
