[GeoNode-devel] groups permissions in 2.4
Rainer Lissewski r.lissewski at aplikate.eu
Tue May 5 02:08:35 PDT 2015
Hi Simone, GroupProfile.objects.all() appears to be empty, this is my
output:
>>> from geonode.groups.models import GroupProfile
_____________________________________
*A P L I K @ T E . E U <http://www.aplikate.eu/>*
Linux, GIS and database developer team
Wittmannsdorfer Str. 4
12053 Berlin
Germany / Allemagne
Tel.: +49 (0) 30 28 45 40 71
Mobil: +49 (0) 163 681 77 34
Fax: +49 (0)30 / 48 49 81 286
2015-05-05 10:57 GMT+02:00 Simone Dalmasso <simone.dalmasso at gmail.com>:
> Rainer,
> I can't replicate the behavior, I create a group in the group tab and then
> it's available in the autocomplete. The function that is handling that is
> this one
> https://github.com/GeoNode/geonode/blob/master/geonode/views.py#L70 and
> it simply does a GroupProfile.objects.filter.
> Can you try to run these commands:
> $ geonode shell
> and see whether it's correctly returning your groups.
> 2015-05-05 10:26 GMT+02:00 Rainer Lissewski <r.lissewski at aplikate.eu>:
>> Hi Simone,
>> I installed 2.4.0+beta25 from the testing ppa and still I cant get any
>> results from the groups autocomplete field. The response for the ajax
>> request is {"count": 0, "users": [], "groups": []}
>> I added an '*' to the  the ALLOWED_HOSTS in local_settings.py, if thats
>> of any importance for above problem.
>> 12053 Berlin
>> Germany / Allemagne
>> 2015-05-04 14:31 GMT+02:00 Rainer Lissewski <r.lissewski at aplikate.eu>:
>>> super thanks! I'll just use a fresh vagrant vm
>>> 12053 Berlin
>>> Germany / Allemagne
>>> 2015-05-04 14:25 GMT+02:00 Simone Dalmasso <simone.dalmasso at gmail.com>:
>>>> Yes will overwrite the current one. I suggest you to use a new Ubuntu
>>>> though. Because until we release the final the upgrade between versions may
>>>> not be smooth.
>>>> Il lunedì 4 maggio 2015, Rainer Lissewski <r.lissewski at aplikate.eu> ha
>>>> scritto:
>>>>> oh wow! will this be available via ppa directly?
>>>>> 12053 Berlin
>>>>> Germany / Allemagne
>>>>> 2015-05-04 13:35 GMT+02:00 Simone Dalmasso <simone.dalmasso at gmail.com>
>>>>>> weird, anyway I'm going to release e new beta today, you can install
>>>>>> it and should solve. If you install it within 4 hours you'll get a faster
>>>>>> and better geonode.
>>>>>> 2015-05-04 13:33 GMT+02:00 Rainer Lissewski <r.lissewski at aplikate.eu>
>>>>>>> exactly, the autocomplete isnt working
>>>>>>> 12053 Berlin
>>>>>>> Germany / Allemagne
>>>>>>> 2015-05-04 13:29 GMT+02:00 Simone Dalmasso <
>>>>>>>> On my 2.4 after I create a group in the groups section then it will
>>>>>>>> appear in the autocomplete. Is it not working for you?
>>>>>>>> 2015-05-04 13:25 GMT+02:00 Rainer Lissewski <
>>>>>>>>> Ok I installed on trusty 14.04 and it is  2.4.0+beta24 (just
>>>>>>>>> checked via aptitude).
>>>>>>>>> Still if I try to set groups permissions as in screenshot below, I
>>>>>>>>> can't choose any existing group..
>>>>>>>>> [image: Inline-Bild 1]
>>>>>>>>> 12053 Berlin
>>>>>>>>> Germany / Allemagne
>>>>>>>>> 2015-05-04 13:19 GMT+02:00 Simone Dalmasso <
>>>>>>>>>> Hi yes, is implemented and available in the ppa:geonode/testing.
>>>>>>>>>> Beware that geonode 2.4 is available only on ubuntu 14.04.
>>>>>>>>>> 2015-05-04 13:15 GMT+02:00 Rainer Lissewski <
>>>>>>>>>> rainerlissewski at gmail.com>:
>>>>>>>>>>> Hi is the full groups permissions system implemented in 2.4 as
>>>>>>>>>>> available in the ubuntu *ppa:geonode/testing *repo?
>>>>>>>>>>>  I saw  https://github.com/GeoNode/geonode/pull/1406 and it
>>>>>>>>>>> appears to be merged still on my 2.4 installation from abovementioned ppa
>>>>>>>>>>> the functionality isnt there..
>>>>>>>>>>> Kind regards
>>>>>>>>>>> _______________________________________________
>>>>>>>>>>> geonode-devel mailing list
>>>>>>>>>>> geonode-devel at lists.osgeo.org
>>>>>>>>>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-devel
>>>>>>>>>> Simone
>>>>>>>> Simone
>>>>>> Simone
>>>> Simone
> Simone
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20150505/486648fc/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20150505/486648fc/attachment-0001.png>
More information about the geonode-devel mailing list
