[GeoNode-devel] groups permissions in 2.4
Rainer Lissewski r.lissewski at aplikate.eu
Tue May 5 02:18:45 PDT 2015
Hi I found the problem now:
I was creating a group only  through the /admin/auth/group/ link. Then this
group doesnt show up in the autocomple / GroupProfile.objects.all() Object.
The good way to create a group that actually works is
through /admin/groups/groupprofile/add/ . After doing that the group shows
up in  /admin/auth/group/ too and can be granted permissions.
Should this go into the docs?
KInd regards and many thanks for your help and patience. Big up GeoNode!
_____________________________________
*A P L I K @ T E . E U <http://www.aplikate.eu/>*
Linux, GIS and database developer team
Wittmannsdorfer Str. 4
12053 Berlin
Germany / Allemagne
Tel.: +49 (0) 30 28 45 40 71
Mobil: +49 (0) 163 681 77 34
Fax: +49 (0)30 / 48 49 81 286
2015-05-05 11:11 GMT+02:00 Simone Dalmasso <simone.dalmasso at gmail.com>:
> Ok so the problem seems to be that you have no groups.
> How did you create the groups? The correct way is to create them through
> the Groups section in GeoNode.
> 2015-05-05 11:08 GMT+02:00 Rainer Lissewski <r.lissewski at aplikate.eu>:
>> Hi Simone, GroupProfile.objects.all() appears to be empty, this is my
>> output:
>> >>> from geonode.groups.models import GroupProfile
>> 12053 Berlin
>> Germany / Allemagne
>> 2015-05-05 10:57 GMT+02:00 Simone Dalmasso <simone.dalmasso at gmail.com>:
>>> Rainer,
>>> I can't replicate the behavior, I create a group in the group tab and
>>> then it's available in the autocomplete. The function that is handling that
>>> is this one
>>> https://github.com/GeoNode/geonode/blob/master/geonode/views.py#L70 and
>>> it simply does a GroupProfile.objects.filter.
>>> Can you try to run these commands:
>>> $ geonode shell
>>> and see whether it's correctly returning your groups.
>>> 2015-05-05 10:26 GMT+02:00 Rainer Lissewski <r.lissewski at aplikate.eu>:
>>>> Hi Simone,
>>>> I installed 2.4.0+beta25 from the testing ppa and still I cant get any
>>>> results from the groups autocomplete field. The response for the ajax
>>>> request is {"count": 0, "users": [], "groups": []}
>>>> I added an '*' to the  the ALLOWED_HOSTS in local_settings.py, if thats
>>>> of any importance for above problem.
>>>> 12053 Berlin
>>>> Germany / Allemagne
>>>> 2015-05-04 14:31 GMT+02:00 Rainer Lissewski <r.lissewski at aplikate.eu>:
>>>>> super thanks! I'll just use a fresh vagrant vm
>>>>> 12053 Berlin
>>>>> Germany / Allemagne
>>>>> 2015-05-04 14:25 GMT+02:00 Simone Dalmasso <simone.dalmasso at gmail.com>
>>>>>> Yes will overwrite the current one. I suggest you to use a new Ubuntu
>>>>>> though. Because until we release the final the upgrade between versions may
>>>>>> not be smooth.
>>>>>> Il lunedì 4 maggio 2015, Rainer Lissewski <r.lissewski at aplikate.eu>
>>>>>> ha scritto:
>>>>>>> oh wow! will this be available via ppa directly?
>>>>>>> 12053 Berlin
>>>>>>> Germany / Allemagne
>>>>>>> 2015-05-04 13:35 GMT+02:00 Simone Dalmasso <
>>>>>>>> weird, anyway I'm going to release e new beta today, you can
>>>>>>>> install it and should solve. If you install it within 4 hours you'll get a
>>>>>>>> faster and better geonode.
>>>>>>>> 2015-05-04 13:33 GMT+02:00 Rainer Lissewski <
>>>>>>>>> exactly, the autocomplete isnt working
>>>>>>>>> 12053 Berlin
>>>>>>>>> Germany / Allemagne
>>>>>>>>> 2015-05-04 13:29 GMT+02:00 Simone Dalmasso <
>>>>>>>>>> On my 2.4 after I create a group in the groups section then it
>>>>>>>>>> will appear in the autocomplete. Is it not working for you?
>>>>>>>>>> 2015-05-04 13:25 GMT+02:00 Rainer Lissewski <
>>>>>>>>>>> Ok I installed on trusty 14.04 and it is  2.4.0+beta24 (just
>>>>>>>>>>> checked via aptitude).
>>>>>>>>>>> Still if I try to set groups permissions as in screenshot below,
>>>>>>>>>>> I can't choose any existing group..
>>>>>>>>>>> [image: Inline-Bild 1]
>>>>>>>>>>> 12053 Berlin
>>>>>>>>>>> Germany / Allemagne
>>>>>>>>>>> 2015-05-04 13:19 GMT+02:00 Simone Dalmasso <
>>>>>>>>>>>> Hi yes, is implemented and available in the
>>>>>>>>>>>> ppa:geonode/testing. Beware that geonode 2.4 is available only on ubuntu
>>>>>>>>>>>> 14.04.
>>>>>>>>>>>> 2015-05-04 13:15 GMT+02:00 Rainer Lissewski <
>>>>>>>>>>>> rainerlissewski at gmail.com>:
>>>>>>>>>>>>> Hi is the full groups permissions system implemented in 2.4 as
>>>>>>>>>>>>> available in the ubuntu *ppa:geonode/testing *repo?
>>>>>>>>>>>>>  I saw  https://github.com/GeoNode/geonode/pull/1406 and it
>>>>>>>>>>>>> appears to be merged still on my 2.4 installation from abovementioned ppa
>>>>>>>>>>>>> the functionality isnt there..
>>>>>>>>>>>>> Kind regards
>>>>>>>>>>>>> _______________________________________________
>>>>>>>>>>>>> geonode-devel mailing list
>>>>>>>>>>>>> geonode-devel at lists.osgeo.org
>>>>>>>>>>>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-devel
>>>>>>>>>>>> Simone
>>>>>>>>>> Simone
>>>>>>>> Simone
>>>>>> Simone
>>> Simone
> Simone
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20150505/58e1143f/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20150505/58e1143f/attachment-0001.png>
More information about the geonode-devel mailing list
